bumpdE30 0 Report post Posted March 5, 2007 i read the sticky thread above and on an e30 320i rear brakes there is a use only once bolt.. is it definitly not reuseable? and out of curiousity why is that? where can i get another bolt if i dont buy genuine bmw pads? thanks guys Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted March 5, 2007 Hey there. Me personaly, I would be happy reusing as ive done many times but would put a bit of thread lock just to be safe. The bolt could be a stretch bolt but im not sure there. Just dont tighten the hell out of it. Quote Share this post Link to post Share on other sites
will 169 Report post Posted March 5, 2007 i read the sticky thread above and on an e30 320i rear brakes there is a use only once bolt.. is it definitly not reuseable? and out of curiousity why is that? where can i get another bolt if i dont buy genuine bmw pads? thanks guys there are different brake setups for the rears, the on Andrew describes is an earlier setup, yours may be different, so check. I go with Steve's remark, I would reuse the bolt but with locktite or similar. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted March 5, 2007 My last set of pads (not genuine BMW) came with a new bolts and they were pre coated with thread lock. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted March 5, 2007 My last set of pads (not genuine BMW) came with a new bolts and they were pre coated with thread lock. which bolts are these exactly? is it on the drum set-up? because i have never come across them on my rear discs. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted March 5, 2007 the rears dont have em and the fronts do just a little bolt to hold caliper together...its re usable, again with loc tite most new pad sets come with a couple of extra bolts. Quote Share this post Link to post Share on other sites
bumpdE30 0 Report post Posted March 5, 2007 thanks everyone for the help, really appreciate it. its nice to get such good reponce insted of being called an idiot. so cheers!! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 6, 2007 Just some info - use-once bolts are designed specifically with 'give' in them so at the correct tightening torque they fatigue slightly (stretch) and "Lock" in place. Once this has happened, the bolt/nut will not do it again. Hence the reason many people reuse them but with loctite. Quote Share this post Link to post Share on other sites
