Evo30 6 Report post Posted May 21, 2014 Hi, I got asked this by a few people and I saw a few people struggling to get these off.Example below: Very easy to removal and clean up. Most people with E30's exposed to a lot of weathering will have this stuff brittle and when touched, it crumbles. It is not heat insulation as it is not fire proof. Anyway... I recommend removing the bonnet before doing this, or just tarp over the engine. What you need: 10mm wrench/ratchet (to remove bonnet) - well mine was 10mm....Plastic scrapper GLUE REMOVER! -- Ooomph from Bunnings works sweet - or anything with citrus. Wax and grease remover Rags A MASK! at least for the first bit. Frame 1- 1. Optional, I removed the bonnet. Ensure you mark its mounting.2. Put mask on or harden up. Use plastic scrapper to make sure all foam is removed and glue is exposed. Water blaster is easiest.Frame 2- 3. Spray Ooomph and walk away, for about 30 minutes! Make sure all exposed adhesive are drenched. I left it and ate dinner or something. The longer you leave it the better as long as it doesn't completely dry off. Frame 3- 4. Use plastic scrapper to peel off the adhesive. This takes a while you may need to repeat process 3.5. Once all is gone, use wax and grease to remove anything excess. 6. Spray Ooomph on to a clean new rag, go over the whole bonnet once more.DONE! put bonnet back on. easy as. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 21, 2014 Or just water blast it off. Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted May 21, 2014 Try water blasting mine off didnt work very well got all the loose crap off tho Quote Share this post Link to post Share on other sites
Evo30 6 Report post Posted May 21, 2014 waterblasting is fine if you have access to one, i rather clean it off with solution, your gonna clean it anyway. this only cost $10 Quote Share this post Link to post Share on other sites
Allanw 1072 Report post Posted May 22, 2014 Dads wasn't too bad, so we were got it off it chunks, then replaced it with brand new - less than $120 from memory. Quote Share this post Link to post Share on other sites
