redmdamson 0 Report post Posted November 4, 2018 Hey guys I just got the FixD diagnostic reader and it’s showing me the voltage of 1,2,5,6 o2 sensors. My guess is that I need to replace 2 and 6 due to the lack of flux they're doing. Would I be wrong? I also know there is a gouge in the exhaust that I need to take care of (drivers side of the two before the resonators(. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted November 4, 2018 Could it be that sensors 1 and 5 are pre-cat and 2 and 6 are post -cat? Quote Share this post Link to post Share on other sites
redmdamson 0 Report post Posted November 5, 2018 I couldnt seem to find An answer on which sensor is where. Google had failed me. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted November 5, 2018 49 minutes ago, redmdamson said: I couldnt seem to find An answer on which sensor is where. Google had failed me. The reader tool you purchased will not help you diagnose faults properly. The vehicle needs better diagnostic systems to do that and a person with a qualified brain to use it. The faults you have will probably be the result of a problem and not be the actual fault. O2 sensor faults are normally triggered by lean or rich mixture problems Quote Share this post Link to post Share on other sites
redmdamson 0 Report post Posted November 5, 2018 I know darn sure that there is an exhaust leak that is part of the reason I’m getting the codes p0420 and p0430. Could that leak be the only cause or is it likely the o2 sensors are bad because of the gouge? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted November 5, 2018 After cat exhaust leaks won't cause O2 sensor fault codes. What driving problems or issues are you having with the vehicle ? Quote Share this post Link to post Share on other sites
redmdamson 0 Report post Posted November 5, 2018 The hole is before the cats. Just replaced the water pump due to a leak and the check engine light has been on for a while due to p0420 and p0430. my heat has been finicky lately too but since I just got this car more recently it seems to drive the same as before. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted November 5, 2018 What model car? They're both codes for cats, so I would probably check if they have been removed Quote Share this post Link to post Share on other sites
redmdamson 0 Report post Posted November 5, 2018 8 hours ago, dirtydoogle said: What model car? They're both codes for cats, so I would probably check if they have been removed It’s a 328i and I was told that the reason for those codes could be faulty sensor, hole in exhaust, or cats are failing internally. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted November 5, 2018 Or the cats have been gutted the correct way to test your cats for being blocked is with a manometer The correct way to check your o2 sensors with with a gas analyser But won't hurt to check for leaks at all or damage to the cats Quote Share this post Link to post Share on other sites
redmdamson 0 Report post Posted November 7, 2018 Thank you all for your help folks! Quote Share this post Link to post Share on other sites
