LsBeema 468 Report post Posted July 15, 2020 (edited) Stocking up for Christmas gifts .....the cam, port and tune..??? Edited July 16, 2020 by LsBeema 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 16, 2020 Very nice. Let us know your experience with them as I will need to purchase a set at some point. Quote Share this post Link to post Share on other sites
aja540i 1906 Report post Posted July 16, 2020 If you are mainly working on aluminium you can get specific ones with a bigger gap between the teeth that helps stop them from clogging up and lets them cut faster. Those ones should be pretty good on steel ( new ones are always good) but will probably clog pretty quickly with aluminium. You can also get longer shank versions that can be useful for porting. 2 Quote Share this post Link to post Share on other sites
LsBeema 468 Report post Posted July 17, 2020 On 7/17/2020 at 5:30 AM, aja540i said: If you are mainly working on aluminium you can get specific ones with a bigger gap between the teeth that helps stop them from clogging up and lets them cut faster. Those ones should be pretty good on steel ( new ones are always good) but will probably clog pretty quickly with aluminium. You can also get longer shank versions that can be useful for porting. Thanks man. Quote Share this post Link to post Share on other sites
