325_driver
Whining Noises
hey guys
when i start the car and the engine and stuff is cold theres a whining noise, i think from the back ?
could that be the diff?
could this be part of the previous problem i have ?
if i try and idle in first gear it puts the car into a major bunny hop ?
sound any thing familiar?
thanks guys
yeah dude id say its your diff, try throttle out of a corner it should bunny hop too? chances are a gear has gone..
coast the car in neutral at around 50 - 70 kmh if u hear a whine coming from the back, it would indicate your diff pinion/crown gears are worn. Have you tryed replacing the fluid? does it make whining/rattling noises when turning sharp corners ?
I'd say older cars tend to be a bit noisier when they are cold. In saying that tho, are you sure the whinning is not coming from the passenger's seats when your not driving alone ? could be two problems here lol
Is the whine there when you are not moving?
it starts whining (when cold) when i start moving. mite pay to replace diff fluid
tried throtlling round corners at all soughts of speeds.
but the only problems im having is when im going slow in first gear.
if im going like 20 in first and plan the foot no problems
but it seems anywhere below that speed too much power will put it into a bunny hop ?
so no gears gone?
just the diff on the way out ?
what sought of price am i looking at ?
does any one have a solution ?
maybe i should invest in my lsd now ?
cheers guys
so no gears gone?
cheers guys
typing on a keyboard is not gpoing to fix ur problem dude, we can only suggest and comment what the problem mite be providing you give us all the relevant info (which u have done so)
if your diff is poked, then it should whine/rattle at all speeds, if its only in 1st, then it sounds like something in the gearbox is playing up...maybe a bearing is on its way out? what about in 2nd gear when its cold, same problems?
^^ this guy is on to it! never read that it only does it in 1st.. sounds g/box related. take to specialist for road test if you arent sure?
Maybe the mother in law in the back seat?
im just running round in circles here
it sounds like something wierd
im just gunna take it to sherson autos
i think as soon as steve takes it for a test drive hell know
its really hard to explain via typing
but thanks for all you help any way
what sought of price should i pay for a lsd for my car ne how ?
ive been wanting to get one quoted up
