pureboiracer 0 Report post Posted April 18, 2007 hey iv got a motronic ecu at home from a 1985 325i and ive got a 1987 325i motor. its the motor where the dissy is up by the cam and is controlled electronicly i think im not sure as i dont have the dissy. do you guys know if this ecu will work or do u guys know how i can find out? Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted April 18, 2007 (edited) The distributor is mechanical on both motors, but it sounds like you have a pre f/l ecu (l-jetronic) and a f/l motor (motronic) so you'd need a motronic ecu. edit: no-one wants a moronic ecu... Edited April 18, 2007 by bravo Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted April 18, 2007 There are no L-jet 325s'. All 325 are Motronic, but they are not all the same. The ECU from a 85 through to mid 87 will not interchange with the later (late 87 on) ECU. Quote Share this post Link to post Share on other sites
nath 131 Report post Posted April 18, 2007 If your car is pre- FL and has the small oval shaped diagnostic plug in the engine bay, then yes the ECU will work. (im crossing my fingers that you have a FL engine so i can buy your ECU off you!) Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted April 19, 2007 There are no L-jet 325s'. All 325 are Motronic, but they are not all the same. The ECU from a 85 through to mid 87 will not interchange with the later (late 87 on) ECU. true. So is it motronic 1 vs 1.1? while we are on the topic I'd be interested to know in general what vehicles ran what. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 19, 2007 Motronic (BOSCH) computer from 1989 325i Motorsport.. numbers 0 261 200 164 1722190 001 made in germany. these are the details i know about it. i am not sure about the plug in the engine as the engine is not in the car yet. how can i tell if my motor is pfl or fl? Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted April 19, 2007 isn't there only motronic 1.1 (pre 87) and 1.3??? 1.1 has not got a o2 sensor, where the 1.3 has? the crank angle senors are in different places. so alittle splicing and soldering will be required for it to work Quote Share this post Link to post Share on other sites
will 169 Report post Posted April 19, 2007 how can i tell if my motor is pfl or fl? what does the crank pulley look like? Does it have a whole bunch of teeth on it around the edge? (motronic 1.3) or is it smooth around the edge (motronic 1.1) Your ecu is motronic 1.3, has 3 rows of pins, motronic 1.1 has 2 rows of pins. Check the engine loom ecu plug, I suspect it will be 2 row type from the age of the motor you quote. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted April 19, 2007 (edited) isn't there only motronic 1.1 (pre 87) and 1.3??? that's what I meant - I don't know everything you know - I just act like I do. Edited April 19, 2007 by bravo Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 20, 2007 so if the ecu fits the loom it will work? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 22, 2007 hey i chekd out loom etc. there are 2 pins for the ecu. it has i diagnostic plug also. is this fl or pfl? also i need a distributor for it. the dissy is up by the cam and there is a blank plate on the side of the block where the other dissy sits. could i use the dissy out of my 320i which is on the side of the block? and wat about the 320i ecu? would that work? Quote Share this post Link to post Share on other sites
