User Name 19 Report post Posted May 23, 2007 Im wanting to put a pod filter into my 528i anyone got any suggestions on what to put Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted May 23, 2007 Apexi Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted May 23, 2007 Factory airbox probably outperforms. Remove any baffling from the inside of it, baffling thats there purely to cut down intake noise. There's apparantly a tube in the 328i that when removed makes it sound just that bit more awesome - Alas none in my 320i. Put a k&n panel filter in if you want to do something. Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted May 23, 2007 or get an engineer or metal worker or similar to make you up a tube to connect a pod filter to, just make some measurements, someone would most likely do it for a cash job for you. Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted May 23, 2007 Cheers for that guys ill have a look at the factory box and see if i can do anything with it, otherwise ill just go with the pod idea Quote Share this post Link to post Share on other sites
BreakMyWindow 1965 Report post Posted May 28, 2007 probably a waste of time putting a pod filter in, it will only end up sucking in hot air. If done properly i.e ram air intake style, u would probably only see minimal difference.... its the intake manifold which is the bottleneck in there engines from what i gather. Still each to their own :-) Quote Share this post Link to post Share on other sites
joshuaraolah 0 Report post Posted June 16, 2007 which do u guys think is better, aperx or k&n filters, im also hearing about simota filters are they any good? Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted June 16, 2007 probably a waste of time putting a pod filter in, it will only end up sucking in hot air. If done properly i.e ram air intake style, u would probably only see minimal difference.... its the intake manifold which is the bottleneck in there engines from what i gather. Still each to their own :-)Don't you have to put a heat shield around filter? Quote Share this post Link to post Share on other sites
dickhead 0 Report post Posted June 16, 2007 take it off and put a stocking over the end of the piping... lol... you do notice the difference, especially on a cold day Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted June 17, 2007 I notice my car going better on colder days with stock airfilter/airbox. Its just because cold air is denser. Quote Share this post Link to post Share on other sites
