User Name
Pod filters
Im wanting to put a pod filter into my 528i anyone got any suggestions on what to put
Factory airbox probably outperforms. Remove any baffling from the inside of it, baffling thats there purely to cut down intake noise. There's apparantly a tube in the 328i that when removed makes it sound just that bit more awesome - Alas none in my 320i.
Put a k&n panel filter in if you want to do something.
or get an engineer or metal worker or similar to make you up a tube to connect a pod filter to, just make some measurements, someone would most likely do it for a cash job for you.
Cheers for that guys ill have a look at the factory box and see if i can do anything with it, otherwise ill just go with the pod idea
probably a waste of time putting a pod filter in, it will only end up sucking in hot air. If done properly i.e ram air intake style, u would probably only see minimal difference.... its the intake manifold which is the bottleneck in there engines from what i gather. Still each to their own :-)
Don't you have to put a heat shield around filter?
take it off and put a stocking over the end of the piping... lol... you do notice the difference, especially on a cold day
I notice my car going better on colder days with stock airfilter/airbox. Its just because cold air is denser.
