OLLIE
Hell BM - Forum Sponsor
Hi Ray,
Would you have the spreadable lock from the handbrake mechanism of an E21? Apparently it is the same part no. as found on E30s. It's a cable operated device that locates (and spreads) the handbrake shoes.
I think i got some side skirts from this guy today, but he gave me wrong color.
First of it was a windscreen then i found out the windscreen was for a Coupe and then he said he would change for the side skirts i was going to buy of him, and i get home and they are not the same color as car ( he said they were the exact same color?)
Did you take the car or did you just tell him the colour?
If you are not happy give Ray a ring - I'm sure he'll do the right thing and either refund you or swap you if he has something else.
He came around with them, i wasn't home he must have noticed they were silver when my car was right next to where he put them.
Give him a call. Keep calm and be reasonable and I'm sure he'll sort you out.
If you don't get a happy solution post back here.
yay for Ray! required a power steering pump for me '97 320 and he had me sorted out in a jiffy. muchos gracias mate :)
Yes.
Contact me on 0212435526
Regards Ray
Hey mate,
Do you have a air flow meter for my e36, Part : Bosch 0 280 212 010, also a factory filter box? and would you be able to send them to christchurch if so?
Cheers,
Hi Ray
Do you have an airbag for the centre of the steering wheel for a 2000 E46 door 323 ?
Also 2 rear arm rests in black and rear tail lights with the clear indicators housings? I also have tear in the leather gear cover surround on the auto that needs replacing?
  bma-cruzn said:
Hey mate,
Cheers,
Should do. Will check tommorow and pm you.
Regards Ray
0212435526
  Mr Beam said:
Hi Ray
Have some items. Will check tommorow and pm you.
Regards Ray
0212435526
  1988E305SPD said:
Ray ,
Have you got any bonnets for a 318i e30 1988, if so what colours if need be ill have to get it re painted,
Yes, in various colours.
Ray
0212HELLBM
Hey do you have any passenger front guards for a e30 in calypso red? Cheers, Nathan
hey mate i need a right hand side window regulator 4 e30 coupe. have u got 1 and how much would it be? If not where could i get one?
thanks
belated thanks to Ray for sorting me a pair of original bosch headlights after wof experience involving shady aftermarket crystal headlamps. the original bosch look so much better and the e36 has lost that tacky looking front :D
great service as always.
  ---blair--- said:
hey ray,
im after an e30 manual gear shifter
leather boot
and a nice e30 or e36 gear knob
cheers blair
Ditto as above minus the gear knob to suit E30
Flicked you a text last week but havent heard anything.
Got anything lying around?
Cheers,
Matt
Try forum sposor Gavin (Euro-Italian ph. 09 4449817)
Regards Ray
Complete M Tech 1 Kit (front, rear sides and boot) $950
Like this:
Have some. What are you after?
Like this:
Ok, would you sell it minus the boot spoiler?
