OSiRiS 0 Report post Posted July 15, 2007 Hey all. This would be my first problem since owning a BMW (approx 1 month now) All of a sudden my E36 fuel gauge has just stopped working? It was working fine and reading half tank when I came home. Parked up. Went out a few hours later and I noticed that it's stuck past empty with the fuel light on. I thought maybe there actually was no petrol in it so I filled it up and it didn't move. Thanks in advance, OSiRiS Quote Share this post Link to post Share on other sites
M325is 0 Report post Posted July 15, 2007 Annoying promblem I know. I had same thing but my fuel light still worked. Brought a new fuel gauge but now it reads full at way past the full mark and empty reads about 2mm to the left of half way and the petrol light still works at this empty point. I gave up trying to fix it as I hated pulling the gauges out, so now I just fill up every 300miles. Gauge problems suck arse. Quote Share this post Link to post Share on other sites
sami911 0 Report post Posted July 15, 2007 Hey all. This would be my first problem since owning a BMW (approx 1 month now) All of a sudden my E36 fuel gauge has just stopped working? It was working fine and reading half tank when I came home. Parked up. Went out a few hours later and I noticed that it's stuck past empty with the fuel light on. I thought maybe there actually was no petrol in it so I filled it up and it didn't move. Thanks in advance, OSiRiS Hi , This is easy one , all you got to do is replace the fuel float in the fuel tank You can ring me on 0800 BMW 992 OR 579 3331 Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 15, 2007 E30 had same problem.Fuel level sender in the fuel tank which is under the seat.Guess it's probably the same on an E36. Stuck a new one in (after trying three that didnt fit) and it was sweet. Worth a try Quote Share this post Link to post Share on other sites
OSiRiS 0 Report post Posted July 15, 2007 Thanks all I'll give it a shot. Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted July 18, 2007 Yep if its an import it more than likely will be the 'nissan one' and if its nz new it will be 'zf'. A common prob - which is what happened to mine ('96 323i Coupe import) is flaring between 2nd/3rd, and if you haven't got a warrenty can be very expensive. Mine was fully re-coned and the bill was around the $3k mark!! Had the exact problem as described. I just CRCed the connectors to the level sender and it started working again :-) Worth giving a try before replacing anything. Another thing that seems to get it to work and I dunno why is this. 1) disconnect the connectors to the level sender and pump (they are together on the right hand side sender under the back seat) 2) Start the car it will sputter and die after a few second since you have disconnected the pump. 3) Switch off the engine before it dies. 4) Reconnect the sender and pump. 5) It worked for me :-) Good luck! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 18, 2007 None of that will work on an E36 Its a broken wire on the sender unit in the tank I can rewire it for you Just give me a call Cheers Glenn Quote Share this post Link to post Share on other sites
HELLBM 1695 Report post Posted July 18, 2007 Glen has the correct information. A common problem. Regards Ray 0212HELLBM Quote Share this post Link to post Share on other sites
Jammasterjames 0 Report post Posted February 3, 2008 This just happened to me... :-( Whicketyy whikkety Whack !! Quote Share this post Link to post Share on other sites
