charlie01 0 Report post Posted August 30, 2007 Hey there, Just new to Bimmersport. Yesterday i bought a 328i 90,000kms. It drove fine all day, until last night t quickly and suddenly overheated and lost all of its coolant . suspected thermostat problem however mechanics have replaced the thermostat and the problem continues.... any suggestions what could be wrong? is this a common fault? many thanks for your help Charlie C Quote Share this post Link to post Share on other sites
charlie01 0 Report post Posted August 30, 2007 Theromstat will not cause it to lose water. Can you see where the water is coming out - to lose a lot of water quickly it should be obvious, and it needs to be up to temperature to circulate around radiator. . Possible problem is a split radiator side tank i agree with you my friend, no leaks etc found. bmw have reccomended a new radiator to fix the problem... going to get expensive Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted August 30, 2007 i agree with you my friend, no leaks etc found. bmw have reccomended a new radiator to fix the problem... going to get expensive Not if you go to someone like Ray who can sort you out replacement parts - VERY ECONOMICAL! I would personally take the car back from where you bought it and get them to fix!!! Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted August 30, 2007 Common problem is sidetank hoses popping off.. nothing a bit of vacuum hose and some epoxy can't fix... Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted August 30, 2007 Consumer Garuntees Act FTW! depending where you brought it of course. When i brought mine the airbag sensor under the passengers sent f**ked out and brought up a fault on the dash, cost just under a grand to fix at Jeff Grey Bmw but the car yard i brought it off paid. Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted August 31, 2007 mine over heated a few days back, mine was a stuck thermo stat. however.. in my quest for solutions I talked to a friend who used to have over heating problems, he got nearly everything replaced, but it still happend, turned out there was a crack in the head.. and needless to say VERY expensive to fix, id get whoever you bought it off to fix it, if you can that is, Quote Share this post Link to post Share on other sites
charlie01 0 Report post Posted August 31, 2007 i got it from turners auctions in penrose. i doubt they will be willing to pay a cent.. new radiator and thermostat went in today... the problm is still there.. could it be the waterpump or worst case.. water jacket seal? Quote Share this post Link to post Share on other sites
charlie01 0 Report post Posted August 31, 2007 i am told the head gasket and ngine have been checked to be in good condition, this is such a confusing situation Quote Share this post Link to post Share on other sites
bmw.maniac 1 Report post Posted August 31, 2007 (edited) i got it from turners auctions in penrose. i doubt they will be willing to pay a cent.. new radiator and thermostat went in today... the problm is still there.. could it be the waterpump or worst case.. water jacket seal? I was at Turners for yesterday's auction and didn't any 328i's - or even any e36's for sale bar one 318ti. Strange Edited August 31, 2007 by Eddy Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted September 1, 2007 there is only a couple of options left. Water pump, you have air trapped in the system,the cooling system must be bled of air not 100 percent sure of m54? engines but the the connection between radiator and coolant resevoir must be clear you might have a blown headgasket. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted September 1, 2007 correct me if im wrong but turners should still be obligated by the consumers gaurentees act, unless you signed somthing waiving this right, youd be looking at alot of money to fix if its the head gasket, if i was you id look into turners see if the cars are covered by the consumers gaurentees act then fight turners to fix it or refund you the cash Quote Share this post Link to post Share on other sites
Keitipai 0 Report post Posted September 2, 2007 I had this problem with mine on my first long trip back from up North. after 3 hrs my coolant light suddenly came on and I was losing water almost as fast as I could put it in. Turned out that the aircon belt had been rubbing on one of the hoses the whole trip down and had finally wore through. Quote Share this post Link to post Share on other sites
isis 16 Report post Posted September 4, 2007 you must have a dumb ass mechanic that can't seem to trouble shoot the situation. You should have just replaced the thermostat and the water pump - could have had the platic unit - that usually breaks. The next is the side tank at the side of the radiator - made of plastic and does crack over time. Quote Share this post Link to post Share on other sites
charlie01 0 Report post Posted September 5, 2007 got it sorted. was the waterpump, radiator side tank and thermostat. what a mission lol. car runs like new again!! thanks for all your help Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted September 11, 2007 got it sorted. was the waterpump, radiator side tank and thermostat. what a mission lol. car runs like new again!! thanks for all your help luckily the overheating didnt crack/warp the engine useless Quote Share this post Link to post Share on other sites
