c.robertson00 11 Report post Posted December 7, 2007 Where is the cheapeset place to get these bushes so im changing gear instead of stiring porridge lol. I have tried the local bmw dealership but they were prity pricey. Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted December 7, 2007 Where is the cheapeset place to get these bushes so im changing gear instead of stiring porridge lol. I have tried the local bmw dealership but they were prity pricey. i think i need the same for wen i du my manual conversion Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted December 7, 2007 talk to warren at BM warehouse in hamilton . he buys direct from germany . Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 7, 2007 (edited) No-one (AFAIK) has the front knuckle bush aftermarket. They all supply the OEM one, so you won't get much better than the dealer anyway. Expensive I know (about $90-100 from memory?) Edited December 7, 2007 by bravo Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted December 7, 2007 As mine needs doing as well, what is the process for actually replacing this bush i gather it involves unbolting drive shaft and lowering down the gearbox cross member & Possibly removing the engine mount bolts to tilt the engine to gain enough access ? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted December 7, 2007 get some urethane cut offs and make your own, its not hard PM me to get details when so i remember to post up Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 9, 2007 Can you do that on the front knuckle joint Gus? Its the same type of bush as on the end of the gear lever. I'd guess you could do it with a press? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted December 9, 2007 (edited) The front knuckle is the most likely culprit and while you can do this without dropping the g/box it's a damn site easier with the box off. Is an OEM part. Image doesn't help but at least you can see where it is, it's alittle T bar with c-clips, tricky little bloody things to work with when there's no room. Edited December 9, 2007 by Mr. Pink Quote Share this post Link to post Share on other sites
