DrphTa 5 Report post Posted December 10, 2007 the brakes have just worn out on my e36 325i was looking into getting bigger brakes as i may aswell seeing there off and bigger brakes is such a great idea lol. can someone point me in the direction of sizes, brands etc. cost.. i only want fronts btw. rears do not need replacing. i have been quoted $600 for both front rotors and pads for orginal bmw parts cheers for the helps guys Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted December 10, 2007 Stick with the OEM rotors and get proper pads for it. A much better option. Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted December 10, 2007 e46 330 rotors seem to be popular over seas, or M3 brakes? Quote Share this post Link to post Share on other sites
HELLBM 1648 Report post Posted December 10, 2007 E46 330 calipers and rotors (larger than E36 M3 Brakes) fit straight on. 17`s are needed for adequate clearance. Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted December 10, 2007 I am running stock rotors and pads on a 328 which are bigger than yours but had Mintex 1166 pads previously. The stock combo works better than the 1166 on the road and never had any fade, car is tweaked to 168 kW and driven quickly. Stock set up is good if in good nick. Can someone elaborate on the 330 rotor size 330i size is 325mm x 25mm. you need the calipers and the caliper carriers. Direct bolt on. You also need minimum 17" wheels. Then for a firmer pedal, you need the E36 M3 master cylinder. Its pretty good for a cheap option BUT it adds a SHITLOAD of unsprung mass from the bigger calipers and the bigger rotors = slower acceleration. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted December 10, 2007 do you really need bigger brakes? stock pads and discs are awesome Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted December 10, 2007 Stick with the OEM rotors and get proper pads for it. A much better option. suggest any pads cain? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 10, 2007 do you really need bigger brakes? stock pads and discs are awesome True story this. I guess if the 328 brakes are larger then that would be a good idea. If the brake cylinder is any bigger than your current ones you'll need the master cylinder too. You wont out drive them on the road. Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted December 11, 2007 I'm running Mintex 1166 pads (on an E34). They definitely generate less dust than the OEM Pagids and when you track the car hard, they don't fade anywhere near as quickly. When I need to replace them, I will probably do it again. They have given great life. I seriously doubt that you need bigger brakes (unless you are planning a big jump in power). 3pedals is correct, for day to day driving the OEM setup is pretty good. I am unsure (as I'm too lazy) whether any of the forum sponsors do pads. But talk to them if they do, otherwise go to 0800racebrakes. Better tyres will enhance your braking more than bigger brakes, and will stick in corners better. Quote Share this post Link to post Share on other sites
PBOY23 0 Report post Posted December 11, 2007 http://www.trademe.co.nz/Trade-Me-Motors/C...n-131388129.htm hmmmmmmmmmmmmmm i wounder? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 11, 2007 http://www.trademe.co.nz/Trade-Me-Motors/C...n-131388129.htm hmmmmmmmmmmmmmm i wounder? i have some good used ones like those $120 the pair (like new thickness) 021433600 ah Quote Share this post Link to post Share on other sites
