pureboiracer 0 Report post Posted December 11, 2007 i was looking through my haynes manual for the e30 the other day and noticed it mentioned carby moters a few times and then i thought. (being a huge carby fan) how easy would it be to decide to be different and carby my fl m2ob25 engine. ok i figured i would have to replace intake manifold and dizzy and fuel pump and filter and pull out all the loom etc but i was just wondering if it would be a mamoth job or weather it is feisable??? Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted December 11, 2007 (edited) I'm a big fan of carbs myself but have to ask why bother? Its going to be a potentially expensive exercise. If you are looking for more performance then a cam and extractors are a must as the carbs are not going to do it on their own. There are manifolds available for triple weber or Dellorto setups - so here's a link to a pdf file that may be useful. I think the L-jetronic will lend themselves better than the motronic engines as you will not need to use the ECU at all. http://www.piercemanifolds.com/mangoletsi.pdf Edited December 11, 2007 by ducatiss Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted December 11, 2007 I don't know much about mechanics but what's the advantage of carb over fuel injection? Why wouldn't most car manufacturer keep using them? I only know of muscle cars (Mopar or GM specials as seen on the show Overhauling) and hot-rods are still using carb (well, and my old school Mini). Why? Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted December 11, 2007 omg side drafts on e30 Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 11, 2007 I don't know much about mechanics but what's the advantage of carb over fuel injection? Why wouldn't most car manufacturer keep using them? I only know of muscle cars (Mopar or GM specials as seen on the show Overhauling) and hot-rods are still using carb (well, and my old school Mini). Why? No advantage at all. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted December 11, 2007 yeh you are right as there is sweet f.a advantage but how many e30s to you see driving around with sidedrafts on them? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted December 11, 2007 does anyone know if the old carby 6cyl bemer manifolds will fit onto a m20 head? if i can get a manifold to fit then the rest is just plain sailing Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted December 11, 2007 the plan (if any) would be to completely rip out every single wire in the car hang a ljet dizzy down the side of the block and make my own wiring oh and get a smaller fuel pump and there realy shouldnt be toooo much more to it than that Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 12, 2007 (edited) e21 323i had m20 with carbs. Copy that setup and use those parts for ease. I don't know how hard it would be though. To answer the question as to why manufacturers don't use them - its because injectors make a motor much more economical and it can be tuned more accurately with fuel injection. If you just want to pour fuel down its neck and go like the clappers then you can use carbs, but still would prob be better off just using an uprated injection system with tunable fuel and spark. Carbs sound badass. Edited December 12, 2007 by bravo Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted December 13, 2007 side drafts Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted December 13, 2007 daym dat is mint. wonder what he did in the means of intake manifolds? just made his own? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted December 13, 2007 side drafts AH!!!! VERY SUCKY MOTOR Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 13, 2007 I went from original 4 barrell solex to L-jet injection in my E12 M20 -way better now than on carb -performance & economy Was easy enough - fit L-jet manifold assy, overlay L-jet wiring / ECU into car, fit electric pump in rear. No reason you cant go the other way but I wouldn't. You would require an external fuel pump as the pump drive point is blank in the E30 block casting. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted December 14, 2007 just out of curiosity how much performance would you loose by going carby? because i am planning to do this in my e30 and the idea of the project is to have something different and it will be a fun track car. would you still get some decent performance when you also whack on a lumpy cam and extractors etc?????? Quote Share this post Link to post Share on other sites
