Nobimmer 694 Report post Posted January 21, 2008 Redoing the back, almost done but got a whole lot of alternator whine...before I run 0 gauge from the battery I wanna try find another spot in the boot. At the moment I am using one of the top shock bolts as the earth...its sanded etc but still whinges. ANyone? Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted January 21, 2008 Redoing the back, almost done but got a whole lot of alternator whine...before I run 0 gauge from the battery I wanna try find another spot in the boot. At the moment I am using one of the top shock bolts as the earth...its sanded etc but still whinges. ANyone? Negative terminal on the battery would be the best earth , but I suspect your picking up the noise from else where Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted January 21, 2008 (edited) Negative terminal on the battery would be the best earth , but I suspect your picking up the noise from else whereAgreed!It won't be the earth wire thats causing the noise. Where have you run the power and RCA's? Are they run together or two seperate paths? If you've run them together down the same path thats ya problem, or running RCA's thru the middle. I recently wired up my e36 with a sub. RCA's down the drivers side, Power down the passengers, Earth from the tow bar bolt in the boot. No noice what so ever. Let me know, and ill try to help. Edited January 21, 2008 by 3 SERIES Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted January 21, 2008 i agree , dont run power wires next to rca ones and also turn down gain level on your amp. make sure your headunit has good earth also . get better unsulating rca cables? Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted January 22, 2008 Ashkan, if battery is in the trunk the power cable will run from driver's side into the engine bay, so run the RCAs down the passenger side. Good grounding point would be the stock grounding point, remove your rear seat backs and it'll be behind the rubber mat. Can't miss it. There will already be a rubber plug that allows wires to run from the boot to the grounding point. It's the most professional way to do it if cable length allows. Quote Share this post Link to post Share on other sites
isnowi 0 Report post Posted January 22, 2008 Would you by chance be using an alpine head unit? if you can't get a clean sound no matter what you do in the way of signal/power cables then it is possible that the unit itself is damaged, i had one a few cars back that did the same thing, turned out that a track had been damaged in the power supply section of the unit, the added resistance made for a nasty whine that i couldn't get rid of no matter what i did. The solution was simple in the end....I bought an Audi. cheers, Dan Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 22, 2008 heres what I did yesterday. checked all RCA's etc were sweet-didnt work checked all the earths were fine and ran a 0 gauge wire out of the car straight to amp- didnt work ripped all the seats/speakers etc out...still wasnt working. Unplugged the new infinity tweeter from the circuit and tadah was sweet as...so spent half the day trying to figure out why the f**k it wouldnt work.Then I say that the screw I had screwed through the B pillar to hold the tweeter was touching the body of the car and the solder from the speaker wire onto -ve terminal was touching the screw ( i suck at soldering)...just put a bit of insulation tape over it and SAAAWEEEET! Getting good sound now,just waiting for my D class amp to arrive to power the sub...got my old JVC dummied up for now. Cheers for the help guys Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted January 22, 2008 Good to hear you found the problem! Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 23, 2008 God damn it's back...same speaker and everything,must be grounding itself somewhere again. Next week when my new Dclass amp arrives I'm going to do it all over agian and run all new cables etc etc. Will post pics for anyone intersted. Quote Share this post Link to post Share on other sites
GLIDN 0 Report post Posted January 24, 2008 your best would be that you may have rca or speaker wire passing over a audio wire? if so, and you have no choice but to run them over one another. Cross the wire over at a 90' degree crossing. That should hopefully eliminate your whine, or one other place i managed to pick up whine noise once. My earth on my stereo became exposed and got it that way. I have no idea how open earth can cause whine, but it did. Check those 2 things, hopefully you should be sorted. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 26, 2008 Yeah it's definitly that same speaker just grounding on something random...so gonna run all new wires and replace all the factory sh*t. should be fun Cheers for the help man,Rca's are run down seperate sides of Gbox tunnel and don't touch apart from in the boot. Quote Share this post Link to post Share on other sites
pfm 0 Report post Posted January 30, 2008 Sometimes the experts are a bit misleading in what they recommend. Don't use a Braided or sheilded cable on Audio line or Speakers. Use the fattest 2 core multi stranded cable you can. Stick thru' a shield or even Tin foil wrap the whole thing. Always seperate 'low level' (audio) from power looms. Braid earth straps every 1.75m. on the exhaust to body, and extreme cases graphite grease and powder in the tyres - done the lot over the years, but some vehicle are produced only test your patience in the interference department. Cheers Paul - E30 Sound Promotions Quote Share this post Link to post Share on other sites
PBOY23 0 Report post Posted January 30, 2008 are you running 6.5 in the rear ? iv made my packers 18mil mdf at the front what are the exact make and model ? Quote Share this post Link to post Share on other sites
Five Star 0 Report post Posted January 31, 2008 Pfft rears. Are all your amps grounded in the same place? There's mixed opinions on RCA's picking up noise from power wire, with a lot of people saying it's impossible. But I figure it's not worth the hassle to find out.. If you list all your gear and check all your wiring that'll help a lot. Have your RCAs ever touched? That generally buggers up pioneer units good. As long as you're not going for 130db+ , if it looks like a strong connection and it's all sanded you should be fine. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 31, 2008 Running 6.5 rears yup. Fronts are infinity Kappa components and the rears are JVC something or rather. JVC 4 channel 80w RMS amp for fronts at each channel Sony D class 650 rms monoblock amp for sub Infinity Kappa (i think) Sub Using 0 gauge wire cos I had some lying around. Will do it all again and let you know how it goes Quote Share this post Link to post Share on other sites
