Silver Fox 43 Report post Posted November 24, 2008 Riley, you need the diff out of a E28 525e, usually 2.93, 3.07, or 3.25 med cases. Just change the output shafts and back cover and clutch pack and off you go. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted November 24, 2008 I have a spare 3.46 LSD, not low enough I know, but I want a 3.73 for my car heh.. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted November 24, 2008 Riley, you need the diff out of a E28 525e, usually 2.93, 3.07, or 3.25 med cases. Just change the output shafts and back cover and clutch pack and off you go. This is what i think ill have to do mate. Trying to save $$ as usual Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted November 24, 2008 Yo Riley You should investigate to see if you can swap over the crown wheel and pinion from a regular NON LSD diff that would means heaps of ratio options and a brilliant chance to fit more clutch packs for higher lockup Seems like a better way to do it than fitting a large case diff I don't see how BMW would make the med case diff totally different in design just because it was an LSD, only the center should be different. We might have to check into this more Jimmy, pretty sure that guy i no has a 535i with the diff. I no the diff looks very different however the guts might be the same?? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted November 28, 2008 Theres a write up here on making an LSD using the LSD from one diff into an open diff. http://www.e30tech.com/forum/showthread.ph...;highlight=diff Seems simple enough? Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted November 29, 2008 Theres a write up here on making an LSD using the LSD from one diff into an open diff. http://www.e30tech.com/forum/showthread.ph...;highlight=diff Seems simple enough? Can't believe i never saw that thread before. Got a LSD centre and 3.64 wheel & pinon been wanting to swap over, thread will help alot. Cheers for that Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted November 30, 2008 Theres a write up here on making an LSD using the LSD from one diff into an open diff. http://www.e30tech.com/forum/showthread.ph...;highlight=diff Seems simple enough? sweet thats dam god info! Quote Share this post Link to post Share on other sites
