Oliver99 0 Report post Posted February 12, 2008 Hey guys, I was just wondering if it is possibe to make your own wheel spaces out of say a 5 mm bit of plate steel. Thanks Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted February 12, 2008 No i would not recommend it. You can buy them very cheap anyway Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 12, 2008 anythings is possible .. you would need access to a fairly accurate lathe. its really is just easier buying some. Make sure you run longer high tensile lugs also. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted February 12, 2008 I tried making them with an engineering mate of mine. Circle looked so damn perfect and spun perfect on the lathe. Put them on wheels and vibrated like mental. For spacers its like 40 each last I looked. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted February 12, 2008 Yes it is possible - but if you have to ask how. You can't do it. Sorry Quote Share this post Link to post Share on other sites
topless 13 Report post Posted February 13, 2008 Most spacers need a cert, that is done for a reason!! Nobody wants to be in the same space as someone who is likely to lose a wheel at any time due to using some makeshift spacers just to look cool.. Quote Share this post Link to post Share on other sites
