tune 0 Report post Posted April 1, 2008 Hey guys is there any way i can check my vin number or something similar to check if the car is an M? other than looking at the M badge its got leather interior sunroof body kit 2.3L manual but all of that could have just been fitted any help would be appreciated Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted April 1, 2008 punch in your chassis number here http://www.bmw-z1.com/VIN/VINdecode-e.cgi or http://www.realoem.com/bmw/ latter one also good for getting /comparing part numbers Works wonders Quote Share this post Link to post Share on other sites
3series 0 Report post Posted April 1, 2008 (edited) the M323i's anyway, I've heard they do exist - come with a dogleg gearbox and LSD. To check for LSD, would be best to look for the tag on the back of the diff, or stamped into it with an S. Edited April 1, 2008 by bmw3 Quote Share this post Link to post Share on other sites
tune 0 Report post Posted April 2, 2008 Gutted, well it doesn't say M anywhere lol Chassis number 7539922 Vehicle code 1172 Series E30 Model 323i Body type coupe Catalog model ECE Production date 1984 / 12 Engine M20 Transmission Manual Steering Right Catalyzer NONE Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted April 2, 2008 (edited) Don't get too despondent about it - they were only upgrades at the factory that anyone can add later on. Just checked out my chassis no on those sites and somewhere my car has grown another couple of doors!! Edited April 2, 2008 by ducatiss Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted April 2, 2008 Don't get too despondent about it - they were only upgrades at the factory that anyone can add later on. Just checked out my chassis no on those sites and somewhere my car has grown another couple of doors!! I believe that the South African and (possibly) Jap cars weren't linked into the main BMW VIN database... especially considering a lot of South African cars were "parts-bin specials". That may be why you get a different car popping up when you enter your VIN number. Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted April 2, 2008 I believe that the South African and (possibly) Jap cars weren't linked into the main BMW VIN database... especially considering a lot of South African cars were "parts-bin specials". That may be why you get a different car popping up when you enter your VIN number. You might be right as my car was originally from Sth Africa. Then it was exported to Japan and finally a few years later into NZ. And even with a history like that it has over the three years or so that I have owned it, it has proven to be very reliable. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted April 2, 2008 (edited) I've seen an M323i which had a dogleg box. Not sure if it had an LSD. It was NZ new, and approx 1985. Edited April 2, 2008 by CamB Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 2, 2008 if you have to ask - it's not depending how you define M. many people have cars with M bits on them (which have their own value) such as LSD, body kits, sport seats etc (I would not clarify them as an M however) the 323i with the dogleg and LSD seems to have been the predecessor to the 325i Sports - it prob wont have kit, does it have sport seats? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 2, 2008 define M car...you could say your car is an M car if you have a "motorsport" gearknob.Sports seats,sports suspension,and bodykits are the relatively modern intrepretation of an M car. The proper ones will have BMW M POWER on the cam covers,and as many individual throttle bodies as there are cylinders. Quote Share this post Link to post Share on other sites
tune 0 Report post Posted April 3, 2008 (edited) the 323i with the dogleg and LSD seems to have been the predecessor to the 325i Sports - it prob wont have kit, does it have sport seats? it does have a kit, well mine does, and the guy i bought it off said it came out slightly lower when it was made, it is low but not slammed or anything, the front bumper and the underside of the car is quite low. also has a bmw symbol on the back of the diff, will have to jack it up to see if there is a "S" on it anywhere, can see under it much. it does a mint squat when you launch it ground slaps at times and yes it does have sports seats with loads of adjustments and they are leather someone could have just put leather seats in, but the door cars and roof lining would have had to be changed aswell because they are matching Edited April 3, 2008 by tune Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted April 3, 2008 (edited) If you're facing the diff from the back of the car, there should be a little metal tab attached to the diff on the left (passenger) side of the car. EDIT: Look for the S on the little tab to tell if it's an LSD. Or just jack up the car and spin one wheel. If the other goes in the same direction you should have an lsd. Edited April 3, 2008 by JiB Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 4, 2008 If you're facing the diff from the back of the car, there should be a little metal tab attached to the diff on the left (passenger) side of the car. EDIT: Look for the S on the little tab to tell if it's an LSD. Or just jack up the car and spin one wheel. If the other goes in the same direction you should have an lsd. if you look on real oem and punch in your vin then go and check your diff it should tell you the ratio and if its a lsd or not... Quote Share this post Link to post Share on other sites
tune 0 Report post Posted April 4, 2008 If you're facing the diff from the back of the car, there should be a little metal tab attached to the diff on the left (passenger) side of the car. cant see any litttle tab ay. ill jack it up today and try the wheel spin to check the lsd Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted April 4, 2008 Ultimately, if it's not an E30 M3 (easy to spot) or at a stretch an E30 320iS. It's not an M car. It may have some "motorsport kit" items. But it's not an M car. Quote Share this post Link to post Share on other sites
tune 0 Report post Posted April 4, 2008 well is there a type of beamer thats not M that came out with all or some of the M upgrades? Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted April 4, 2008 Yes, there are plenty of those. Mine has all the M5 running gear hooked up to the V8. But it's not an M5 (even though it's rarer). Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted April 5, 2008 (edited) I think this must be one of the most debated topics on the forum - closely behind lowering. I have attached some scans from the E30 brochure on the topic of accessories. Here is some further info for you... "There are several BMW models to which BMW Motorsport made changes without being full M-Cars. Vehicles which have been modified by BMW Motorsport but are not full M-Cars may feature plain 'M' badges with no number, whilst full M-Cars have 'M' badges with the model number. E.g. 'M3' or 'M5'. It should be noted however that the Z3/Z4-based M Roadster and M Coupe bore numberless 'M' badges as standard fitment. For example, the E28 M535i featured suspension, styling, and transmission improvements over the standard 535i. These changes were carried out by BMW Motorsport, thus the car carried 'M' stripe badges on the front grille and boot, but not the full 'M5' badging. The E28 M5 was sold along side the M535i. Motorsport modifications have been made to almost every BMW model, hence it is not unusual to see 'standard' BMW's with 'M' badges. The opposite occurred with the 850CSi, an M car in all but name; it had a BMW M sourced engine and its VIN indicated that it was developed by BMW Motorsport, like all other M cars. It was possible that a true M8 was in development; however, this M8 was cancelled for reasons known only to BMW." sourced from http://en.wikipedia.org/wiki/BMW_M Edited April 5, 2008 by ducatiss Quote Share this post Link to post Share on other sites
m325i 724 Report post Posted April 5, 2008 is it an M? You just have to BELIEVE! Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted April 5, 2008 how bout a car with M325i on the back and has been registed as a 29??cc think its 2983cc (3L) also its a manual Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 7, 2008 Sounds like a cock up to me. Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted April 7, 2008 (edited) I also struggle with xxx"M" automatics - xxx"M" Steptronics I can accept. just my take And yet the E28 M535i were also produced with an automatic trans - straight from the factory. Edited April 7, 2008 by ducatiss Quote Share this post Link to post Share on other sites
