Keats 0 Report post Posted June 24, 2008 hey ive got a 1992 e36 320 and it seems to be hanging in gear just atad to long in like 2nd and third. ive been told that a transmission flush might be the way to go. is it hard to flush the fluid and change the gasket? or does anyone have any better advice? cheers Keats Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 24, 2008 have spare trans if needed. 021433600 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 24, 2008 hey ive got a 1992 e36 320 and it seems to be hanging in gear just atad to long in like 2nd and third. ive been told that a transmission flush might be the way to go. is it hard to flush the fluid and change the gasket? or does anyone have any better advice? cheers Keats It may not necessarily be the trans that is causing this. Get it scanned first. Changing the filter, pan gasket and oil may improve things. However I would suggest you get it scanned by a competant person with a brain first and go from there. Make sure they scan DME, EGS & ABS. The early cars like yours dont have adaptive capability. Quote Share this post Link to post Share on other sites
WarlockNZ 0 Report post Posted June 28, 2008 If your in auckland i can plug you into my scanner and see what your problem is. Quote Share this post Link to post Share on other sites
