tonylauno1 7 Report post Posted July 6, 2008 Engine idles drop dramatically and picks up again when idling cold. It has always does this and one day when I let it idle for a long time, the engine just died. Has anyone experience this before? Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 6, 2008 Posted this in the wrong forum, can someone help move or close this please. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted July 6, 2008 Engine idles drop dramatically and picks up again when idling cold. It has always does this and one day when I let it idle for a long time, the engine just died. Has anyone experience this before? I've had similay experiences with my E39 540i V8 with M62 engine It was a combination of: 1. Dirty, clogged ICV (idle control valve). Cleaned with carb cleaner 2. Faulty coil causing misfires. Replaced coil. Whether the above applies to your car is dificult to determine, as you don't mention what ytpe of car or engine you are talking about !! Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted July 6, 2008 It looks like he's talking about a M52b28, Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted July 6, 2008 said it before and will say it again.... check the air intake pipe for cracks Quote Share this post Link to post Share on other sites
westy 614 Report post Posted July 6, 2008 It looks like he's talking about a M52b28, M52b28tu. Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 7, 2008 oops, always forgetting the most important part. It's a M52B28TU - Westy had it correctly, Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 7, 2008 Get it scanned first Tony before you start fiddling... give me a call if you'd like me to do it for you Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 8, 2008 A friend gave me a bottle of Motorup, and now it seems like it only does it after 4-5 mins of idling. I guess when the engine switches from cold to warm, he reckons it might be the variable timing. Anyway, thanks for the offer. Thanks for the offer, I'll wait till it gets worse or at least does it on every cold start then I'll come and see you. Would be easier to diagnose. Get it scanned first Tony before you start fiddling... give me a call if you'd like me to do it for you Quote Share this post Link to post Share on other sites
