Steve K-B 51 Report post Posted July 15, 2008 Ive got a 1987 325i that I suspect the AFM is rooted as the car is over fueling somthing cronic. Any one know how to test it? or does any one want to lend me a spare one if you have it floating around? Thanks, Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted July 15, 2008 Ive got a 1987 325i that I suspect the AFM is rooted as the car is over fueling somthing cronic. Any one know how to test it? or does any one want to lend me a spare one if you have it floating around? Thanks, You need a gas analyser. I can set it up for you...however it may not be the AFM Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted July 16, 2008 Ive got a 1987 325i that I suspect the AFM is rooted as the car is over fueling somthing cronic. Any one know how to test it? or does any one want to lend me a spare one if you have it floating around? Thanks, Um Steve ... don't you work with Mal? he'll sort you out Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted July 18, 2008 Hey Ollie, Yep I do but he suspects the computer (and he is most probably right) but I figgerd the AFM was the next easiest thing to check. I have since found a haynes manual with testing instructions so ill give it a go this weekend. Thanks for the offer for the gas analyzer but I also have access to one. Quote Share this post Link to post Share on other sites
BM WORLD 1270 Report post Posted July 19, 2008 i have afm and ecu you can try . 021433600 Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted July 22, 2008 Thanks!! Ill give you a call tomorrow. Quote Share this post Link to post Share on other sites
