savvi 0 Report post Posted July 31, 2008 hi all , just wondering wats the best bleeding tool to use , i was thinking of using a pressure bleeder , Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted July 31, 2008 (edited) Clutch slave cylinder? My tools are a cut in half bottle with clutch/brake fluid sitting in it (in case anything gets sucked back in), a rubber hose that fits over the bleed nipple, a ring spanner, and a second person to listen to my "in" and "out" calls, works a treat everytime. Edited July 31, 2008 by QuickSilver Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted July 31, 2008 Clutch slave cylinder? My tools are a cut in half bottle with clutch/brake fluid sitting in it (in case anything gets sucked back in), a rubber hose that fits over the bleed nipple, a ring spanner, and a second person to listen to my "in" and "out" calls, works a treat everytime. same, haha. hasn't failed me yet! Quote Share this post Link to post Share on other sites
williams 0 Report post Posted July 31, 2008 another way if u dont have a pressure bleeder is to connect a 3mm pipe to the left front caliper and to the slave cylinder,then u pump the brakes and it bleeds the slave from the bottom forcing out all the air-clutch in no time!!! Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted July 31, 2008 another way if u dont have a pressure bleeder is to connect a 3mm pipe to the left front caliper and to the slave cylinder,then u pump the brakes and it bleeds the slave from the bottom forcing out all the air-clutch in no time!!! The brakes and clutch aren't connected. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted July 31, 2008 (edited) Hes talking about using the brake system to force the fluid through the clutch line from the slave up. Quite clever. Wonder how well it works. Glenn?? Edited July 31, 2008 by westy Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 31, 2008 Hes talking about using the brake system to force the fluid through the clutch line from the slave up. Quite clever. Wonder how well it works. Glenn?? It does work, a bit of mucking around, and I dont like the idea of pushing old brake fluid up through new clutch cylinders. Just as easy to do a 2 person, pump & bleed, only takes a few minutes Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 1, 2008 It does work, a bit of mucking around, and I dont like the idea of pushing old brake fluid up through new clutch cylinders. Just as easy to do a 2 person, pump & bleed, only takes a few minutes wat fluid/brand would u recommend to use glenn thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 1, 2008 wat fluid/brand would u recommend to use glenn thanks Really dosnt matter so long as it's Dot 4 Quote Share this post Link to post Share on other sites
