JiB 2 Report post Posted August 4, 2008 (edited) $65 to Bimmersporters Edited September 15, 2008 by JiB Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted September 15, 2008 Now on trademe Click here Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted October 12, 2008 Up, $65 is cheeeep I think? Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted January 27, 2009 No one wants a mint rad? Quote Share this post Link to post Share on other sites
BLACK DORIS 9 Report post Posted January 28, 2009 (edited) would it be compatible with a SA 325iA e30? Apparently - these SA models have a larger radiator than other assemblies? Not sure if I need one right now (in a slow, fairly expensive process of elimination...) but 65 sounds reasonable. Any idea on freight/postage to welly? cheers Rio Edited January 28, 2009 by BLACK DORIS Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted January 28, 2009 No idea on postage sorry Quote Share this post Link to post Share on other sites
BLACK DORIS 9 Report post Posted January 28, 2009 Sweet, I may be able to get one here in welly. Still interested to know if that rad would work in an auto 325i... Anyone know? Cheers. Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted January 28, 2009 i'm guessing it would work with a 320i? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 28, 2009 Probably not a 325iA, as the ones I have seen (only a couple) had part of the radiator reserved for auto trans fluid. Possibly a 320i. I would expect (but not promise) that it would bolt in to all of them, but that whether it works on your car depends on which configuration of hoses you have. You can see in the picture that the in/out are top right/bottom left. According to the online ETK, the radiator is the same for Euro 323i and 320i pre-facelift, manual and auto. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 28, 2009 I have a F/L E30 325 Auto one for sale $100 Quote Share this post Link to post Share on other sites
BLACK DORIS 9 Report post Posted January 29, 2009 I have a F/L E30 325 Auto one for sale $100 Should have mentioned it's pre f/l, although that may not matter? Think I might have found one in welly. Cheers tho! Will pm you if not!! Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted January 30, 2009 Do you have a pic of the top of the radiator? Had a look at my mates 320i and he has a tube thing which goes into an overflow. And his top hose connector appears to be moved further to the left I think from what I can remember. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 30, 2009 Radiator is 440mm wide. The top hose is 80mm (to the centre of the hose) from the RHS of the radiator, and the outlet for the expansion tank is in the RHS of the hose behind the square bit in the pic on the top of the radiator (if that makes sense). Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted January 30, 2009 Radiator is 440mm wide. The top hose is 80mm (to the centre of the hose) from the RHS of the radiator, and the outlet for the expansion tank is in the RHS of the hose behind the square bit in the pic on the top of the radiator (if that makes sense). Cheers Cam, will measure it up Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted May 6, 2009 Anyone keen? Quote Share this post Link to post Share on other sites
bmw335i 16 Report post Posted May 8, 2009 Anyone keen? hi could be keen for a Quick $50? Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted May 8, 2009 hi could be keen for a Quick $50? Yup, sure. Lemme dig it out of storage for ya. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted November 19, 2009 Upski Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted December 5, 2009 Up, $40? Quote Share this post Link to post Share on other sites
