stylish_division 0 Report post Posted August 11, 2008 Ive finally found a transmission fluid 'dipstick' in my 98 e36 318i... does this car have a different transmission to the 316i...as the dipstick was more obvious in that one. Anyways its running real low, so i was wondering if there is a special transmission oil for it? or will any auto transmission fluid do? while im at it, any recommendations for topping up engine oil also. cheers Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 11, 2008 I just use dextron 3 for my auto and think used 15w-40 in my engine i think but yea ATF is ATF check what the bmw manual says and work from there Quote Share this post Link to post Share on other sites
stylish_division 0 Report post Posted August 11, 2008 I just use dextron 3 for my auto and think used 15w-40 in my engine i think but yea ATF is ATF check what the bmw manual says and work from there thanks, forgot about manual. Also do the msports have a different gearbox? i have been told this. is this why my dipstick is different from my 316i non m sport? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 11, 2008 Ive finally found a transmission fluid 'dipstick' in my 98 e36 318i... does this car have a different transmission to the 316i...as the dipstick was more obvious in that one. Anyways its running real low, so i was wondering if there is a special transmission oil for it? or will any auto transmission fluid do? while im at it, any recommendations for topping up engine oil also. cheers It will take either full synthetic G3 or longlife oil, dependant on transmission type The engine, I would recommend 15W40 we use ELF, but any well branded oil is OK Quote Share this post Link to post Share on other sites
