Luke 0 Report post Posted October 23, 2008 Hey, Ok well i have just finished doing a manual conversion on my e28 (525e) and now the thing wont start.. well it turns over but doesnt fire.. Do i need to join any wires together to make start (all ready done the wires to the auto shifter) Any help would be great. Cheers, Luke Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 23, 2008 what was the manual kit from ??, did the flywheel have the metal trigger point sticking out . also have you bypassed the automatic kill switch so it starts in any gear etc ? the kit would have needed to be from another 525e manual or a preface lift e30 325i . Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 23, 2008 box was out of a 83 520, And no the flywheel didnt have the little lug sticking out like the flexy plate did. Is there any way to by pass those sensors that went into the bell housing on the auto box? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 23, 2008 box was out of a 83 520, And no the flywheel didnt have the little lug sticking out like the flexy plate did. Is there any way to by pass those sensors that went into the bell housing on the auto box? The short answer is NO The sensors are for the ignition and injection systems. The car will not run without them You have fitted the wrong gearbox and flywheel Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 23, 2008 This one would work I believe? http://www.trademe.co.nz/Browse/Listing.aspx?id=182102947 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 23, 2008 This one would work I believe? http://www.trademe.co.nz/Browse/Listing.aspx?id=182102947 He's taken the auto out and fitted manual though Dave Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 23, 2008 The add's not clear Glenn, but the car he's selling is the BMW 520 Blue 1984 cloth trim 329462 km not going suit parts manual. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 23, 2008 yes like i said only a flywheel from a early e30 325i pre face lift or a e28 525e will do . you could weld a trigger point on to the flywheel ( my freind did one a few years ago ) or you could convert the ecu system to post 88 325i or e34 525i m20 set up with the engine loom front hub and front crank sensors etc , but it wont run right with out getting the ecu remapped etc . i think it will be easier to weld a trigger point on the flywheel and cost a lot less in labour etc . has to be in the correct place , try ernst at baverian motors he did my freinds one . Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted October 23, 2008 (edited) you could weld a trigger point on to the flywheel ( my freind did one a few years ago ) ... has to be in the correct place , try ernst at baverian motors he did my freinds one . The box will need the bellhousing modifed as well (if it doesn't have the sensor holes in it). Edited October 23, 2008 by CamB Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 23, 2008 This one would work I believe? http://www.trademe.co.nz/Browse/Listing.aspx?id=182102947 Ha, this ma sound funny but that is the one i bought last weekend. box and all is in my car now Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 23, 2008 (edited) Ha, this ma sound funny but that is the one i bought last weekend. box and all is in my car nowdoes the box have the castings that stick out to except the sensors once you have drilled them out .if not then start looking for a newer manual gearbox kit . try some of the wreckers around some times they have odd boxes and flywheels . Edited October 23, 2008 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 24, 2008 ok, so lets say i went with the 325i or e34 525i m20 ecu and loom, how/ where does the crank angle sensor go.. are the like the comin ones that go on the front of the crank? Wires = Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 24, 2008 (edited) ok, so lets say i went with the 325i or e34 525i m20 ecu and loom, how/ where does the crank angle sensor go.. are the like the comin ones that go on the front of the crank? Wires = its a real major to do that converssion .you will need complete engine loom , ecu , afm all sensors etc( about $500-800 worth ) . also the front hub/pully from the donar engine will have to splice into your old engine loom to make it work .then reprogramme the ecu (aboyut $1200) so the car will run at its best (as the 325/525i are tunned complety different to the 525e) just mod the flywheel . does the gearbox have the castings sticking out to fit the sensors into. like in the picture ? might be easier to find the right gearbox and flywheel , you have done most of the work so far Edited October 24, 2008 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 24, 2008 na mate my box doesnt have those castings in it. So now im going to try find a 525e box. Does anyone wanna buy a e28 520 5speed gearbox Quote Share this post Link to post Share on other sites
HELLBM 1695 Report post Posted October 24, 2008 na mate my box doesnt have those castings in it. So now im going to try find a 525e box. Does anyone wanna buy a e28 520 5speed gearbox Call or text me for the parts you need.Regards Ray 0212435526 Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 24, 2008 na mate my box doesnt have those castings in it. So now im going to try find a 525e box. Does anyone wanna buy a e28 520 5speed gearbox you can also use a box from a e30 325i preface lift will have the holes drilled already post faclift 325i you will need to drill the holes out same as a M20 powered e34 525i 520i etc.try get the matching flywheel if you can with the trigger point as well maybe do a trade as the later M20 engined cars dont need the castings on the box or trigger point on the flywheel Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 25, 2008 (edited) Call or text me for the parts you need. Regards Ray 0212435526 Well.... i need a 525e manual gearbox and flywheel that would be mint if you have them Will i need another drive shaft, or will the 520 one still fit on the 525 box? Edited October 25, 2008 by OmEn Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 30, 2008 So if i put a 325i box in my car, will i need to shorten my drive shaft or change the yoke,? Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 30, 2008 (edited) So if i put a 325i box in my car, will i need to shorten my drive shaft or change the yoke,? . same box different output falnge maybe look at it see if you can fit the front section of the e30 shaft to the rear section of the e28 shaft .get the flywheel as well if you can so you dont have to weld a trigger point on . Edited October 30, 2008 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Luke 0 Report post Posted October 31, 2008 ok cheers mate Quote Share this post Link to post Share on other sites
