325_driver 422 Report post Posted November 2, 2008 hey guys, just wondering what could have caused this wondering if any one knows the wiring diagram in relation to the lights on the e30. The left low/dip beam, and right hand High beam have lost power, e.g. checked the bulbs, and there seems to be no power coming through the connection. And the dash doesnt seem to light up also so . . . Is this all related ? Am i going to have to take the dash out to follow the wires from the lights switch through to the connections ? where does the power meet up for the lights ? Any help would be awsome Cheers guys Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted November 2, 2008 any assistance ? before i start tearing out my dash for no reason ? could it be a relay problem ? Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted November 2, 2008 Checked the fuses? Quote Share this post Link to post Share on other sites
ashy_aye 3 Report post Posted November 3, 2008 could just be a problem in the light switch unit, (the part u pull to turn on) i had this problem once b4. and it ended up just b'n broken connections in the back of the unit. replaced the switch box and now its mint. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted November 3, 2008 I had a problem with several different lights going off at the same time. Turned out to be just a fuse. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted November 3, 2008 what are the fuses for the lights, well high beams to be exact and how do i take this light switch unit out? is the dash coming out too ? thanks heaps, got the low beams all going now, high beams have now mysteriously stiopped, bulbs are fine \ Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted November 3, 2008 Fuse 1 (7.5A) is left high beam, 2 (7.5A) is right high beam for what its worth. Quote Share this post Link to post Share on other sites
lbirgel 0 Report post Posted November 3, 2008 Fuse 1 (7.5A) is left high beam, 2 (7.5A) is right high beam for what its worth. could you please tell me what No. the fuse is for the front spotlights in a e30 325i? cheers Lukas Quote Share this post Link to post Share on other sites
isis 16 Report post Posted November 3, 2008 29 & 30 Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted November 3, 2008 Left foglight- 29 Right foglight- 30 Both 7.5A, relay K8 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted November 3, 2008 this is more than helpfull guys !!!! , thanks heaps, especially when im doing this in the dark lol Quote Share this post Link to post Share on other sites
lbirgel 0 Report post Posted November 3, 2008 great thanks! Quote Share this post Link to post Share on other sites
Driftit 2205 Report post Posted November 3, 2008 If you can not sort it. Go and see Brendon at Hope Hickman Auto Electrical at the Top of Nelson Street in Auckland CBD. He has worked with E30's quite a bit recently and has done alot of work on their headlights. Quote Share this post Link to post Share on other sites
