325_driver
EEEeek Help
hey guys, just wondering what could have caused this
wondering if any one knows the wiring diagram in relation to the lights on the e30.
The left low/dip beam, and right hand High beam have lost power, e.g. checked the bulbs, and there seems to be no power coming through the connection. And the dash doesnt seem to light up also
so . . .
Is this all related ?
Am i going to have to take the dash out to follow the wires from the lights switch through to the connections ?
where does the power meet up for the lights ?
Any help would be awsome
Cheers guys
any assistance ? before i start tearing out my dash for no reason ? could it be a relay problem ?
could just be a problem in the light switch unit, (the part u pull to turn on) i had this problem once b4. and it ended up just b'n broken connections in the back of the unit. replaced the switch box and now its mint.
I had a problem with several different lights going off at the same time. Turned out to be just a fuse.
what are the fuses for the lights, well high beams to be exact
and how do i take this light switch unit out? is the dash coming out too ?
thanks heaps, got the low beams all going now, high beams have now mysteriously stiopped, bulbs are fine
Fuse 1 (7.5A) is left high beam, 2 (7.5A) is right high beam for what its worth.
could you please tell me what No. the fuse is for the front spotlights in a e30 325i?
cheers Lukas
Left foglight- 29
Right foglight- 30
Both 7.5A, relay K8
this is more than helpfull guys !!!! :D, thanks heaps, especially when im doing this in the dark lol
If you can not sort it. Go and see Brendon at Hope Hickman Auto Electrical at the Top of Nelson Street in Auckland CBD. He has worked with E30's quite a bit recently and has done alot of work on their headlights.
