Mercutio 0 Report post Posted November 26, 2008 Hi, I've recently brought a 1989 302i Touring, which I'm enjoying. I was hoping someone could tell me which version of Motronic is fitted to this model. Also... I understand this model has a M20 powerplant, is the 2 litre a smaller bore or stroke? Thanks in advance. M Quote Share this post Link to post Share on other sites
Eagle 1761 Report post Posted November 26, 2008 Preface lift so 1.3 M20B20 Bore 80mm Stroke 66mm according to wiki Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted November 26, 2008 (edited) Preface lift so 1.3 M20B20 Bore 80mm Stroke 66mm according to wiki Correction 1989 = facelift. preface lift did not come motronic. Facelift 320i's only came out with motronic 1.3. This was already mentioned above though! Edited November 26, 2008 by QuickSilver Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 26, 2008 (edited) 320 is 80 bore by 66 stroke, 325 is 84 by 77. Edited November 26, 2008 by Silver Fox Quote Share this post Link to post Share on other sites
Eagle 1761 Report post Posted November 27, 2008 (edited) Correction 1989 = facelift. preface lift did not come motronic. Facelift 320i's only came out with motronic 1.3. This was already mentioned above though! Haha yeah my brain must of failed and added 'pre' Edited November 27, 2008 by Eagle Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted November 27, 2008 Yea will be 1.3. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted November 27, 2008 side topic i have a prefacelift (1986) 325i running a motronic 1.1, or am i mistaken and by this information its actually 1.3? or is this solely referring to 320i's Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted November 27, 2008 side topic i have a prefacelift (1986) 325i running a motronic 1.1, or am i mistaken and by this information its actually 1.3? or is this solely referring to 320i's Check to see if it has a wheel with small teeth ( if i remember correctly ) on it running on the front of the crank with a sensor mounted to the block which reads off the teeth. If it does, its 1.3, if not, its 1.1. Or just find out the number on the ECU and google it. Or unplug the ECU and see how many rows of connectors the plug is, if its 3 rows it is Motronic 1.3. I'd assume it's 1.1 though. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted November 27, 2008 side topic i have a prefacelift (1986) 325i running a motronic 1.1, or am i mistaken and by this information its actually 1.3? or is this solely referring to 320i's preF/L 325i is motronic 1.1 preF/L 320i is Ljet. All F/L 320i and 325i are motronic 1.3 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted November 27, 2008 preF/L 325i is motronic 1.1 preF/L 320i is Ljet. All F/L 320i and 325i are motronic 1.3 Cheers mike, as i thought was just checking though Quote Share this post Link to post Share on other sites
Mercutio 0 Report post Posted November 28, 2008 Thanks everyone... Quote Share this post Link to post Share on other sites
