Mercutio
Motronic 1.1 Or 1.3? (e30)
Hi,
I've recently brought a 1989 302i Touring, which I'm enjoying.
I was hoping someone could tell me which version of Motronic is fitted to this model.
Also... I understand this model has a M20 powerplant, is the 2 litre a smaller bore or stroke?
Thanks in advance.
M
Preface lift so 1.3
M20B20 Bore 80mm Stroke 66mm according to wiki
Preface lift so 1.3
Correction 1989 = facelift.
preface lift did not come motronic.
Facelift 320i's only came out with motronic 1.3. This was already mentioned above though!
Edited by QuickSilver
320 is 80 bore by 66 stroke,
325 is 84 by 77.
Edited by Silver Fox
Haha yeah my brain must of failed and added 'pre'
Edited by Eagle
side topic
i have a prefacelift (1986) 325i running a motronic 1.1, or am i mistaken and by this information its actually 1.3? or is this solely referring to 320i's
side topic
Check to see if it has a wheel with small teeth ( if i remember correctly ) on it running on the front of the crank with a sensor mounted to the block which reads off the teeth. If it does, its 1.3, if not, its 1.1.
Or just find out the number on the ECU and google it. Or unplug the ECU and see how many rows of connectors the plug is, if its 3 rows it is Motronic 1.3.
I'd assume it's 1.1 though.
side topic
preF/L 325i is motronic 1.1
preF/L 320i is Ljet.
All F/L 320i and 325i are motronic 1.3
Cheers mike, as i thought
was just checking though
