stylish_division 0 Report post Posted December 8, 2008 My bonnet window washers have stopped working. No water comes out but wipers go. Have glanced at fuses and they all seem to be in order. and yes there's water in tank. anybody know what the problem could be? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 8, 2008 Blockage in the hoses? Quote Share this post Link to post Share on other sites
stylish_division 0 Report post Posted December 8, 2008 Blockage in the hoses? whats the best way to check this lol. but i did have hood open while i tried to make it squirt....and there was no sound of any operation....not sure if theres supposed to be? Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted December 8, 2008 Have the parts you need.. Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted December 8, 2008 does the pump work?? had this on my car before, blocked nozzles... took it out.. pushed out da blockage with an air compressor... make sure before u disconect the hoses that your pump works.. saves u trouble later Quote Share this post Link to post Share on other sites
stylish_division 0 Report post Posted December 8, 2008 (edited) does the pump work?? had this on my car before, blocked nozzles... took it out.. pushed out da blockage with an air compressor... make sure before u disconect the hoses that your pump works.. saves u trouble later where is the pump and how do i check if it works. ill give it a go tomoro Edited December 8, 2008 by gdm.yo Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 8, 2008 the washer pumps fail often , . i have some 021433600 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 8, 2008 The washer pump is on the side of the washer bottle. Take the plug off and use a test light on the two terminals and get someone to operate the washers. If the test light glows, its the pump thats knackered Quote Share this post Link to post Share on other sites
stylish_division 0 Report post Posted December 9, 2008 checked, test light was glowing so i guess i need a new pump. will contact one of you guys when i have time. cheers for help. Quote Share this post Link to post Share on other sites
