xescuy 0 Report post Posted January 25, 2009 Hello folks, I'm looking for a few opinions on this. The ventilation in my car (E36, 328) is blowing almost nothing at any of the fan speeds. At 1 and 2 there is nothing (just a little bit of fan noise), at 3 there is noise and very little air and at 4 is the same thing, just louder. The fan seems to work but I can't really tell if it's too weak to push the air or there is a loss somewhere in the system. I'm ready to change the resistor pack hoping this will fix the issue. There are some step by step instructions on the net but I'm not sure which side to start on since I don't know if the example is LHD or RHD. Could anyone help? Any of you encountered something like that? Can this also be an issue with a blocked ventilation outlet, valve, etc, etc, Any ideas or recommendations?? It's getting a bit annoying having to wait an eternity till the windows defog or not being able to cool off on a hot day. I'm open for questions if more info is needed. Thanks R Quote Share this post Link to post Share on other sites
williams 0 Report post Posted January 26, 2009 could be that your pollen filter/micro filter is blocked,normally fitted from drivers side foot well,will influence both heater temp and aircon temp +air flow Quote Share this post Link to post Share on other sites
xescuy 0 Report post Posted January 26, 2009 could be that your pollen filter/micro filter is blocked,normally fitted from drivers side foot well,will influence both heater temp and aircon temp +air flow Thought that might be one cause but I was unable to find more on it. Any links to more info on that (DIY steps etc.) ?? Thanks heaps Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted January 26, 2009 Thought that might be one cause but I was unable to find more on it. Any links to more info on that (DIY steps etc.) ?? Thanks heaps http://users.ids.net/~thompson/bmw/microfilter.htmlhttp://www.dvatp.com/bmw/diy/microfilter/ http://www.bmwe36blog.com/2007/12/03/chang...icrofilter-diy/ http://www.unofficialbmw.com/repair_faqs/microfilter.html http://www.unofficialbmw.com/e36/interior/...eplacement.html http://forums.bimmerforums.com/forum/showthread.php?t=363717 Remember with those, they're for left hand drive. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2009 If all the fan speeds are working replace the pollen filter. If you dont have all the fan speeds it will also have a resistor fault...if it is the resistor, I would still fit a new pollen filter as well Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 26, 2009 did the filter in my coupe made a huge difference . easy good , and filters are cheap enough Quote Share this post Link to post Share on other sites
xescuy 0 Report post Posted January 27, 2009 In position 4 the fan is connected directly to 12 volt suuply (resistor pack is bypassed) if you still get NO air movement -- then the air volume problem is not being caused by the resistor pack - Try filter as suggested by others -- also check that the vent controls are working (the ones that direct air to feet / dash vents) you should hear the motors driving when you change distribution selection I can hear noises from inside when changing positions and I can feel a little bit of air at the feet if I close all the dash vents I'll replace the filter and let you know how it went. You guys rule !!! Thanks Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 27, 2009 I have the same prob also, lots of noise but limited air movement. Will try those links. Quote Share this post Link to post Share on other sites
xescuy 0 Report post Posted January 27, 2009 You guys are the best Took the filter out and tested: much better Here is a RHD microfilter replacement DIY : Also took some pics when I did it. Very easy indeed for RHD. 1. take panel out 3 screws and slide out 2.take the vent tube out (might not be necessary but makes things easier if you're not a small person) 3.look for this towards the back 4. slide the mother out and marvel at the dirt coming out with it. BRING VACUUM Good luck. If I was able to do it, anybody can in 10 min or less Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted January 27, 2009 Well done mate. Might do this to mine just to get better ventilation. Do you mind me asking how much the filter was? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2009 Well done mate. Might do this to mine just to get better ventilation. Do you mind me asking how much the filter was? BTW Nick your R/H low beam headlights not working Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted January 27, 2009 BTW Nick your R/H low beam headlights not workingThanks Glenn, I'll go out and check it. New bloody bulbs as well. Quote Share this post Link to post Share on other sites
xescuy 0 Report post Posted January 28, 2009 Well done mate. Might do this to mine just to get better ventilation. Do you mind me asking how much the filter was? REPCO wants a bit over 70 and the $tealer is over 90. Called a few other places in Wellie and all is around the REPCO price. There might be cheaper options but I couldn't find them If anyone knows a good cheap place for BMW parts in Wellington please share Peace R Quote Share this post Link to post Share on other sites
xescuy 0 Report post Posted January 29, 2009 FILTER CHANGED AND ALL IS GOOD !!! WE HAVE AIR Thanks for all the help everybody. Hope this will help someone else also Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 29, 2009 FILTER CHANGED AND ALL IS GOOD !!! WE HAVE AIR Thanks for all the help everybody. Hope this will help someone else also Ha arn't they usaully white, if so that ones been well used!Will definitely be doing this. Quote Share this post Link to post Share on other sites
xescuy 0 Report post Posted January 29, 2009 Ha arn't they usaully white, if so that ones been well used! Will definitely be doing this. I think it was the original one ... HA !!!Yup ... they're white, at the beginning I would recommend it. Easy to do but the filters are bloody expensive. I paid less for an engine air filter which is twice the size. Oh well ... needed doing. Good luck with that. Cheers R. Quote Share this post Link to post Share on other sites
