Creaver 55 Report post Posted February 24, 2009 (edited) So I'm replacing my oil and filter and decide to take off the pan to have a gander...and what do I find but a BOLT SITTING IN THE PAN. My mate who was giving me a hand said supposedly this is quite common, I quickly have a google and WTF DO YOU KNOW, M60's have a problem where oil pump bolts undo themselves? So if you have one, it might pay to get this checked at your next oil change.... Edited February 24, 2009 by Creaver Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 24, 2009 Just as well you found it. I hope you checked them all and refitted them with thread lock. Subaru's are renowned for doing this as well. E30 M40 drop all the internal sump bolts in to the lower sump pan as well causing airation of the oil which causes hydraulic lifter noise and eventually destroys the camshafts. We wont do a camshaft or lifter job on a M40 without doing the sump gasket as well on these. The gasket splits between the bolt holes on the oil gallery for the oil pick up which causes the oil pump to suck air causing the problem. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted February 24, 2009 yes have seen it myself . had a M60 3L engine that was over heated (cracked heads etc) and when i stripped the block down , found 2 bolts in the pan and most of the oil pump bolts where loose .incl the back plate of the oil pump . yea so might pay to check . i also had another 740i e32 w hile ago and the oil light stayed on at low rpm , so gusessing it had the same problem. i have a article from total bmw about the M60 engines . and its mentioned in there along with other faults . Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 24, 2009 i knew....its like the banjo bolts on M30,s Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted February 24, 2009 Yip, retightened and applied some loctite...boy was I surprised. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted February 25, 2009 And the (single) oil pump sprocket nut on my M10. That came off, and I got to pay for a bottom end rebuild including crank grinding and re-nitriding Quote Share this post Link to post Share on other sites
westy 614 Report post Posted February 25, 2009 M5x motors are prone to it too! Theres a trend here?!? Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted February 25, 2009 (edited) M5x motors are prone to it too! Theres a trend here?!? Yep sure are, I had my sump off a few months back and applied thread lock to that nut while it was off as a precaution before the car goes back on the road again Apparantly the RB Nissan motors are also known for this also.... more so the GTR motor correct me if im wrong? Edited February 25, 2009 by Boost Junky Quote Share this post Link to post Share on other sites
