wolliver 1 Report post Posted March 2, 2009 its loose as, i can move it round but sumthing still holding it in, its a PFL E30 Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted March 2, 2009 On the f/l it's simply the two wop bolts, then remove the bracket, plus undo both top and bottom pipes, expansion tank pipe and temp sensor and it just ifts out. Is it auto?? Will also have pipes for auto trans. Make sure it's not just catching on a belt. Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 2, 2009 On the f/l it's simply the two wop bolts, then remove the bracket, plus undo both top and bottom pipes, expansion tank pipe and temp sensor and it just ifts out. Is it auto?? Will also have pipes for auto trans. Make sure it's not just catching on a belt. how do u remove the auto trans pipes?everything else is off Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 2, 2009 how do u remove the auto trans pipes? everything else is off Undo them? Fittings on the LHS. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted March 2, 2009 Be prepared to spill some trans fluid. There are two - one top and one bottom. Quote Share this post Link to post Share on other sites
