Jamez 2147483647 Report post Posted March 6, 2009 allo allo so my 320i m20b20 (pf/l) is hunting once hot, aka non stable idle symptoms go like this Cold - Good idle of ~1000 Warm - Hunting goes from ~1000-1300 Hot - Hunting in full stride, hunts from ~600-1500 most air pipes are new, idle control valve worked perfectly on old engine(using same one) will it hunt if timing is out? ive also read that it can be caused by the AFM but the old engine didn't hunt and used the same AFM, also the ECU worked fine on old engine The twist is, the idle goes up when the oil cap is removed on the old engine the idle would decrease messing with the idle valve doesn't do much also engine does not smoke and makes nearly no mechanical noise, and has good power hope someone can suggest a solution cheers in advance, James Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 6, 2009 (edited) I think you need to buy a E36 Compact Edited March 6, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted March 6, 2009 pffft im saving my penny's for a 325i e30 Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted March 6, 2009 I think you need to buy a E36 Compact Very helpful, Haha. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 6, 2009 Possible vacuum leak. Check all hoses etc around intake manifold and throttle body, esp the large rubber intake boot. If its not that, at least that'll eliminate that as an option. Then check fuel. Maybe ICV is supplying the extra you need when its cold, but its leaning out once it warms up and the ICV shuts off. I'm taking a stab in the dark though. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted March 6, 2009 yeah ive checked all the hoses thrice, im going to get it dyno tuned soon anyway,pretty sure Gavin @ high velocity will sort it out in no time Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 6, 2009 Let us know what the outcome is, mine has a mean dodgy idle, and continually stalls when downshifting up to traffic lights etc, revs drop, engine dies. Quote Share this post Link to post Share on other sites
