Jamez
Pf/L m20b20 idle question
allo allo
so my 320i m20b20 (pf/l) is hunting once hot, aka non stable idle
symptoms go like this
  • Cold - Good idle of ~1000
  • Warm - Hunting goes from ~1000-1300
  • Hot - Hunting in full stride, hunts from ~600-1500
most air pipes are new, idle control valve worked perfectly on old engine(using same one)
will it hunt if timing is out? ive also read that it can be caused by the AFM but the old engine didn't hunt and used the same AFM, also the ECU worked fine on old engine
The twist is, the idle goes up when the oil cap is removed :huh: on the old engine the idle would decrease
messing with the idle valve doesn't do much
also engine does not smoke and makes nearly no mechanical noise, and has good power
hope someone can suggest a solution
cheers in advance, James
I think you need to buy a E36 Compact :P
Edited by *Glenn*
Possible vacuum leak. Check all hoses etc around intake manifold and throttle body, esp the large rubber intake boot.
If its not that, at least that'll eliminate that as an option.
Then check fuel. Maybe ICV is supplying the extra you need when its cold, but its leaning out once it warms up and the ICV shuts off.
I'm taking a stab in the dark though.
yeah ive checked all the hoses thrice, im going to get it dyno tuned soon anyway,pretty sure Gavin @ high velocity will sort it out in no time
Let us know what the outcome is, mine has a mean dodgy idle, and continually stalls when downshifting up to traffic lights etc, revs drop, engine dies.
