pommy 33 Report post Posted March 19, 2009 I need to replace both of my engine mounts I was wondering if anyone has any tips cheers? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 19, 2009 I need to replace both of my engine mounts I was wondering if anyone has any tips cheers? Its easy with an engine crane... I haven't tried with a jack but I'd be very careful. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 19, 2009 easy unbolt rubber mounts top and bottom . lift engine with a jack . rock from side to side to fit newmounts in the drop back down and bolt them up Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted March 19, 2009 easy unbolt rubber mounts top and bottom . lift engine with a jack . rock from side to side to fit newmounts in the drop back down and bolt them up Thanks Mate. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 19, 2009 Careful where you lift the motor from with a jack. If you don't have enough padding/use a block of wood, point loading on the jack cup will crack an alloy sump easy. Quote Share this post Link to post Share on other sites
