welly-e34 0 Report post Posted October 24, 2004 ive got an e34 535 and noticed lately that when i step on the gas...... it seem's to hesitate and sound like it's not running on all cylinders .......very embarrassing especially when leaving intersection's. any help would be appreciated :banghead: Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted October 24, 2004 does it do it when its only i gear? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 24, 2004 When did you last get or do a full service? Quote Share this post Link to post Share on other sites
welly-e34 0 Report post Posted October 25, 2004 it does it when in gear and also when its idling Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted October 25, 2004 not sure about the m30, but check Crank Angle sensor inc wiring, ignition rotor and cap, spark plugs and leads (although they will prob be fine) poss fuel system, but try the others first....sounds similar to what i had a while back which was crank angle sensor wiring....i know how much of a bitch it is! Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted October 25, 2004 ive got an e34 535 and noticed lately that when i step on the gas...... it seem's to hesitate and sound like it's not running on all cylinders .......very embarrassing especially when leaving intersection's. any help would be appreciated :banghead: most likly vac leak .or check all spark plug leads ,cap ,rotor etc Quote Share this post Link to post Share on other sites
welly-e34 0 Report post Posted November 3, 2004 took dizzy cap off today rotor completely gunked up couldnt see any metal on the rotor ...gave it a clean and seems to run a lot better . ill change the rotor/ plug's in the next few days. Quote Share this post Link to post Share on other sites
