smiddy 76 Report post Posted April 30, 2009 Fitted and tested shortie header at Hi Velocity. Was hopeing for more gains but ecu retarding timing when hot. Need to Re-mapp. Around 7 RWHP gain [Auto]. Heaps more throttle response and around 1Ltr/100km fuel gain. Will post Dyno sheets when scanned. Quote Share this post Link to post Share on other sites
jordyboy2 0 Report post Posted April 30, 2009 Im guessing youll be making them, if so How much are these likely to be Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 1, 2009 Im guessing youll be making them, if so How much are these likely to be Hi, Will be $475.00. Thanks. Quote Share this post Link to post Share on other sites
jordyboy2 0 Report post Posted May 1, 2009 Sweet, will need to Make sure its the right engine when it comes back from the body-shop early next week, the badge says 325 but its a 2000 so I think its supposed to be 323 which would be the M52 engine right? If its the correct engine ill defiantly be keeeeen Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 2, 2009 Yes, you should have 2.5 eng. Just check you have mid mount cats. Quote Share this post Link to post Share on other sites
jordyboy2 0 Report post Posted May 2, 2009 Yup i do, ill get back to you after my next payday Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 2, 2009 Have sent PM. Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 11, 2009 Dyno figures for my shorties. Part to mid throttle driving much improved. Jap exhaust restricting top end I think. Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 14, 2009 Thanks Ron, I value your comments. Was hopeing for a little more as you do. The Jap E46 M52 cars have a very average post cat exhaust which I think is restricting top end . Hybrid had his exhaust modded and gained noticable top end power. I think re-mapp also. Who knows how imports are mapped? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 14, 2009 Thanks Ron, I value your comments. Was hopeing for a little more as you do. The Jap E46 M52 cars have a very average post cat exhaust which I think is restricting top end . The 328s average looking single pipe arrangement? You would think there was room for improvement there. The 330s ,like Josh/Hybrids, are a twin pipe system from the factory. Could be an option to look at? Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 14, 2009 Josh's car has cat back fitted now, prior his car had same exhaust, twin from header back to cat, then merge in a crushed pipe arrangement into single out to tailpipe. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 14, 2009 Ahhh ya learn something new every day. Our 330 has twin pipe. NZ new tho. Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 14, 2009 Yes, and no post cat oxy sensors. Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 14, 2009 I hear you Ron and you make a lot of sense. To even get these headers to fit was a mission[rear section]. US speed shops selling them claim 8-10 eng HP, so my power is about right. They are a sport header and are priced to reflect that. The real plus I see now after 3 weeks driving is fuel saving and mid throttle power is way better. Really nice part throttle power. Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted May 17, 2009 Is it safe to assume this will give similar benefits on an E36 M52? Running de-catted twin exhaust (stock). If so, keen to buy a set to try and get extra HP Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 17, 2009 (edited) System is 3/2/1 Ron. Header tube dia is 35mm, runner length average maybe around 35cm. There is a marked differance in head mount plate port size compared to OEM [as per pics]. Edited May 17, 2009 by wayney Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted May 17, 2009 How is progress on the E36 ones Wayne? Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted May 17, 2009 How is progress on the E36 ones Wayne? Have some Brian, just need to trial. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 21, 2009 Picking up the m54b30 ones for the 330i in the next few days cant wait. Quote Share this post Link to post Share on other sites
ieasti 0 Report post Posted June 22, 2009 so anynews for the e46 330 engine? Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted June 22, 2009 Hi Guys, Hybrid is to trial long headers on his 330. Shortie as this topic relates are on my M52 TU and go well. Shorts will fit M50/52/54 with mid mount cats. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted June 22, 2009 As I said in the PM's Im getting about this. Im currently trying to sort out a few sensor related gremlins in my car before changing the exhaust system and introducing another varible. I should have something sorted in the next 4 weeks going well. Sensors aren't the cheapest to replace in the e46 Quote Share this post Link to post Share on other sites
moktar 7 Report post Posted June 22, 2009 Have some Brian, just need to trial. Im also very keen on a set. For E36. Please PM me with price and avalibitly. Thanks Quote Share this post Link to post Share on other sites
