computertrader 0 Report post Posted May 7, 2009 Can anyone assis me with an annoying issue? I just swapped my 92 318i motor to one from a 94 320i and am having issues getting it started, As the car wiring is a bit diffenent i can't determine if the car had some sort of immobiliser, There is an additional green wire in the X20 connector (Pin 7) which i think may be the issue. What signal is this expecting and how can i give it this signal from a 92 car? There was a lot more wiring under the dash of the 94 than the 92 but surely there must be a way to make it work? HELP!!! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 7, 2009 (edited) Can anyone assis me with an annoying issue? I just swapped my 92 318i motor to one from a 94 320i and am having issues getting it started, As the car wiring is a bit diffenent i can't determine if the car had some sort of immobiliser, There is an additional green wire in the X20 connector (Pin 7) which i think may be the issue. What signal is this expecting and how can i give it this signal from a 92 car? There was a lot more wiring under the dash of the 94 than the 92 but surely there must be a way to make it work? HELP!!! Did the info that Brent HARTGE535i give you not help ?or get a non EWS DME Wayne Frost @ EFI TECH in Takapuna can help with that Edited May 7, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
computertrader 0 Report post Posted May 7, 2009 Did the info that Brent HARTGE535i give you not help ? or get a non EWS DME Wayne Frost @ EFI TECH in Takapuna can help with that The info I have managed to find from the links doesn't really help a lot, Only says to buy a new ECU, There must be a way to get it to work without buying a new one? Quote Share this post Link to post Share on other sites
Dogballs 123 Report post Posted May 11, 2009 Check post "Wiring Alarm into central lock" - i posted full e36 wiring diagrams, should show what you need... Quote Share this post Link to post Share on other sites
10hove 0 Report post Posted May 11, 2009 (edited) if your still having isssues give me a call Ive just been through all this myself , early cars had a couple of differnt versions of EWS or Drive away protection, If we can identify exactly what you have Ive got some info that may help cheers Alex 0275 024 817 Edited May 11, 2009 by Alex ten Hove Quote Share this post Link to post Share on other sites
williams 0 Report post Posted May 12, 2009 from memory 4 cylinder and 6 cylinder ews differ, and do not work on each other Quote Share this post Link to post Share on other sites
