caleb 0 Report post Posted May 8, 2009 Jeff grey charges $385 + gst for a battery. Does BMW uses 'special' battery? Can I just buy any normal battery from Repco? Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted May 8, 2009 Jeff grey charges $385 + gst for a battery. Does BMW uses 'special' battery? Can I just buy any normal battery from Repco? Ha, a battery is a battery. In almost all instances OEM batteries are just rebadged from other market brands. Just make sure it is heavy duty and anyway, everyone who you go to will know which is the right battery. Save yourself $$$$ Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted May 8, 2009 Buy the BMW Mini battery ... it's the same as the one in the CSL. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 8, 2009 I have a feeling that the OEM battery is a calcium one (not lead) - which has implications on the charge rate etc. Might be worth a PM to Hotwire or Glenn to confirm if a std battery will be OK or you need a calcium one. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted May 8, 2009 I got a BMW one. Works mint. Won't have any problems. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 8, 2009 I can do a battery for about $250 + Gst. Ring me Monday and I'll give you a sharp deal... prices have all just gone up. It should be a Din 65 Calcium Battery OOOps.... I see your in Wellington ?? Quote Share this post Link to post Share on other sites
superj 0 Report post Posted May 8, 2009 Could offer you a used E46 battery in perfect condition. BMW original. No maintenance required (completely sealed). Has a color dot that shows condition of the battery (green=fully charged, black=re-charge, white=throw it in the bin). If you are interested, PM me. Could give it away for $90. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted May 8, 2009 I have a feeling that the OEM battery is a calcium one (not lead) - which has implications on the charge rate etc. Might be worth a PM to Hotwire or Glenn to confirm if a std battery will be OK or you need a calcium one. Hey there. You are right that it has to be a calcium/calcium battery but locally both major battery providers centuary and exzide produce a calcy/calcy battery. Both are sealed. So they are really no diff to an OEM (and lets be honest here, most OEM batteries will most prob rebadge..though not sure about BMW). As far charge rate is concerned, it is recommened that you get the same cranking amps as that of the original and this is generally dictated by the size of the unit, i.e. that it fits the hole. Hope that helps Quote Share this post Link to post Share on other sites
caleb 0 Report post Posted May 8, 2009 I can do a battery for about $250 + Gst. Ring me Monday and I'll give you a sharp deal... prices have all just gone up. It should be a Din 65 Calcium Battery OOOps.... I see your in Wellington ?? would certainly buy it from you if I'm in AK... unfortunately Was looking at the Bosch catalogue, it doesn't really tell me if I should buy BSDIN65L or BSDIN65LL Which one should I get for 2001 E46 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 10, 2009 would certainly buy it from you if I'm in AK... unfortunately Was looking at the Bosch catalogue, it doesn't really tell me if I should buy BSDIN65L or BSDIN65LL Which one should I get for 2001 E46 Don't quote as I am not familiar with Bosch part numbers but my guess is - probably difference between "L" & "LL" is same battery but one reverse post to the the other. Match configuration layout to your current one. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 10, 2009 (edited) would certainly buy it from you if I'm in AK... unfortunately Was looking at the Bosch catalogue, it doesn't really tell me if I should buy BSDIN65L or BSDIN65LL Which one should I get for 2001 E46 BSDIN65L We sell Century DIN65ZLMF which is a calcium, maintanence free battery and comes with a 3yr warranty Try around the sparkies in Wellington for one of these You should be able to buy it for around $230 + Gst ( just checked my pricing ) Edited May 10, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
caleb 0 Report post Posted May 11, 2009 BSDIN65L We sell Century DIN65ZLMF which is a calcium, maintanence free battery and comes with a 3yr warranty Try around the sparkies in Wellington for one of these You should be able to buy it for around $230 + Gst ( just checked my pricing ) thank you so much Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted May 11, 2009 Ha, a battery is a battery. In almost all instances OEM batteries are just rebadged from other market brands. Yeah right and a car is a car - they all (well most) have a wheel on each corner . Short answer you get what you pay for - cheap chinese made battery will not last or work as well as a well engineered battery from a reputable manufacturer. If yo want a cheap battery - buy one if you want a good battery it wont be cheap. Can easily second that. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 13, 2009 Had some pretty interesting results running a non standard battery for a year. Thanks to ray / hellbm I switched back to the OEM one and what do your know. My issues disappeared. Quote Share this post Link to post Share on other sites
