joel 0 Report post Posted May 11, 2009 Hey guys, im after a clutch kit for my e28 m535. Wouldnt mind getting a slightly better one from overseas but its hard to find for my model. would a e28 m5 clutch like this one fit? http://gripforce.com/store/index.php?main_...;products_id=53 Or any suggestions? Cheers Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted May 11, 2009 Before Glenn suggests it Willy check out UUC in the states - I am gonna look at them for mine when I redo it. http://www.uucmotorwerks.com/ Quote Share this post Link to post Share on other sites
joel 0 Report post Posted May 11, 2009 Simon* said: Before Glenn suggests it Willy check out UUC in the states - I am gonna look at them for mine when I redo it. http://www.uucmotorwerks.com/ That was quick nerd, cheers. had a look but the oldest i could find on that site was e34 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 11, 2009 (edited) GIJoel said: That was quick nerd, cheers. had a look but the oldest i could find on that site was e34 E34 had M30 motors as well... does yours have crankshaft sensors on the gearbox bell housing ??? If it does...I dont think UUC can help...try emailing Rob@shortshifter.com and ask him Or you could try Auto Clutch here in Auckland Edited May 11, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
joel 0 Report post Posted May 11, 2009 im not too sure, dose this help? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 11, 2009 GIJoel said: im not too sure, dose this help? Yes...has the two sensors in the bell housing....lower right in the picture....email Rob, but I dont think he can help you...try anyway Quote Share this post Link to post Share on other sites
joel 0 Report post Posted May 11, 2009 *Glenn* said: Yes...has the two sensors in the bell housing....lower right in the picture....email Rob, but I dont think he can help you...try anywayCheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted May 12, 2009 that one in the link looks ok ,. make sure its for a single mass flywheel , also lighten your flywheel by about 2.5kg while you are at it . 10kg for normal m535i flywheel . m5 uses a 7.5kg one . just had mine done , engine picks up quicker now. i have got clutches from auto clutch in morningside (ak) about 300-400nzd for a complete kit incl bearing and he can do beafier ones if you think you have too much power for a std one Quote Share this post Link to post Share on other sites
joel 0 Report post Posted May 13, 2009 Brent HARTGE535i said: that one in the link looks ok ,. make sure its for a single mass flywheel , also lighten your flywheel by about 2.5kg while you are at it . 10kg for normal m535i flywheel . m5 uses a 7.5kg one . just had mine done , engine picks up quicker now. i have got clutches from auto clutch in morningside (ak) about 300-400nzd for a complete kit incl bearing and he can do beafier ones if you think you have too much power for a std one Cheers, its in there getting ligthened at the moShippings more expensive than the clutch its self from overseas so ill just get one here. might give those guys a call Quote Share this post Link to post Share on other sites
