OSiRiS 0 Report post Posted May 11, 2009 What is this in my exhaust tip? Quote Share this post Link to post Share on other sites
darkwolf 0 Report post Posted May 11, 2009 It looks like a silencer or on closer inspection a butterfly valve? Quote Share this post Link to post Share on other sites
OSiRiS 0 Report post Posted May 11, 2009 It looks like a silencer or on closer inspection a butterfly valve? Seems to me it's a butterfly valve, is this standard? Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted May 11, 2009 Probably, opens in the higher rev's I'd say. Like my GTZ did Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 11, 2009 Seems to me it's a butterfly valve, is this standard? Yes its standard...closes off one exhaust port to stop low speed noise. If you change the rear muffler, just put a small ball bearing in the vacuum hose to block it or else you'll end up getting an engine fault code Quote Share this post Link to post Share on other sites
OSiRiS 0 Report post Posted May 11, 2009 Yes its standard...closes off one exhaust port to stop low speed noise. If you change the rear muffler, just put a small ball bearing in the vacuum hose to block it or else you'll end up getting an engine fault code Oh ok, how can I test that it works? Quote Share this post Link to post Share on other sites
jordyboy2 0 Report post Posted May 11, 2009 Yup looks like the butterfly valve found on some e46's e46fanatics Its used to soften down the tone of the exhaust unfer 4k revs then it opens up irc Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 11, 2009 Oh ok, how can I test that it works? Put your roller skates on and get your girlfreind to tow you round the block Quote Share this post Link to post Share on other sites
danthaman01 0 Report post Posted May 11, 2009 Put your roller skates on and get your girlfreind to tow you round the block and post video after Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted May 11, 2009 Just sit behind the car and have someone open the throttle up in neutral (?) Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 11, 2009 Just sit behind the car and have someone open the throttle up in neutral (?) Car needs to be moving... controlled by DME which needs a speed sensor signal Quote Share this post Link to post Share on other sites
OSiRiS 0 Report post Posted May 11, 2009 Yup looks like the butterfly valve found on some e46's e46fanatics Its used to soften down the tone of the exhaust unfer 4k revs then it opens up irc Thanks! Quote Share this post Link to post Share on other sites
OSiRiS 0 Report post Posted May 11, 2009 Put your roller skates on and get your girlfreind to tow you round the block I would do this but I don't have a towbar! Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted May 11, 2009 Before I read any of the other posts, I thought that it looked like an extra exhaust tip had been welded to the back of the muffler to make it look like a twin, but the valve thingy makes more sense haha... Quote Share this post Link to post Share on other sites
