AzonicNick 0 Report post Posted May 27, 2009 Hey all, am looking at finding some info on a e36 stereo like the one pictured below. Im a big fan of keeping the car oem looking so am wondering if there is a way to connect a AUX cable to it somehow? Just run the cable into the glovebox. Am guessing the only option is through the CD stacker control somehow. Are there any kits out there thatll do this? Also what is the model name of this stereo? I cant find much on google without specifics. photos the same model from a pic on trademe cheers Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted May 27, 2009 (edited) dension.com Edited May 27, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 27, 2009 Also http://www.diceelectronics.com/index.php Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted May 27, 2009 i used to use an itrip before i smashed the screen of my touch it worked surprisingly well, no cords are anything to get tangled up?? just tune into any station and tune on itrip..taadahh Quote Share this post Link to post Share on other sites
AzonicNick 0 Report post Posted May 27, 2009 Those two look good, I had found them using the old google. Also found this which could be good.. http://jcrowell.info/bmw-aux-in.html Might try that.. hopefully wont ruin the head deck! Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted May 27, 2009 or you could adapt the factory cd changer input to except an ipod audio signal , but with out the control side of things like the dension stuff Quote Share this post Link to post Share on other sites
AzonicNick 0 Report post Posted May 27, 2009 Yea that was the other option, I dont really care about controlling the ipod through the unit. Has anybody done it via the stacker controller? I guess its a case of finding the wiring diagram / pin set up and modding a stacker cable to suit? Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted May 27, 2009 Those two look good, I had found them using the old google. Also found this which could be good.. http://jcrowell.info/bmw-aux-in.html Might try that.. hopefully wont ruin the head deck! I have done similar mod on my E39, but I have found that since the tape is a low level input, the volume was a LOT lower than the CD / radio, which was a pian when switching from one source to another. I solved that by putting a line driver ( pre amp ) between the ipod output and the tape inputs, it was adjustable, so i adjusted it so volume is the same as CD/radio, all sweet. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 27, 2009 I solved that by putting a line driver ( pre amp ) between the ipod output and the tape inputs, it was adjustable, so i adjusted it so volume is the same as CD/radio, all sweet. Do you have a link to such a line driver? Thanks! Quote Share this post Link to post Share on other sites
AzonicNick 0 Report post Posted June 4, 2009 Keen to find out also.. Quote Share this post Link to post Share on other sites
