bali_nz 0 Report post Posted July 26, 2009 Hi all, Changed my reversing lamp yesterday (only one going since I bought the car), and since then my EML light has been light, won't even turn off with ignition. Last time it came on was when I left my lights on, and battery died, again ign off, and only EML glowing. But once bat full again, light went out. What does EML stand for, and how do I make the bloody thing go away. Cheers in advance, Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted July 26, 2009 Assuming you have M20 like your info says EML=Electronic motor load regulation. You dont have it. Only on 750i and 535i with ASC IIRC Tried resetting the ecu? Quote Share this post Link to post Share on other sites
bali_nz 0 Report post Posted July 26, 2009 Assuming you have M20 like your info says EML=Electronic motor load regulation. You dont have it. Only on 750i and 535i with ASC IIRC Tried resetting the ecu? Yup, M20B25. It's Schnitzer badged, but don't know what, if any, mods have been done in that respect. Only had it a year. How do I go about resetting the ecu? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 26, 2009 early model e34 have issues with the clusters , the capicators die with old age etc and corrode teh circuit board and cause shorts etc. maybe it has a fault in the cluster , i have spares you can try . Quote Share this post Link to post Share on other sites
