BMWTouring 20 Report post Posted August 6, 2009 Hi guys, what would be the correct diff ratio for a M52 320i been converted to manual?? Cheers. Quote Share this post Link to post Share on other sites
leithcm 0 Report post Posted August 6, 2009 Hi guys, what would be the correct diff ratio for a M52 320i been converted to manual?? Cheers. Depends on the auto you had before. If it was a JATCO, their top gear is 0.7:1 ratio (over drive), so check the diff you have now - it might be 3.64 - or 3.94:1 - not sure. However, this info is on the diff housing. Multiply this by 0.7 and that will give a new ratio (2.64 or so). As the manual gearboxes are 1:1 in top gear this new diff ratio will give the same engine revs in top at a given speed as before. You want to cruise at higher speeds with lower engine revs? Go one step lower in the diff. pretty sure this is how it works, but could be wrong........... Cheers. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted August 6, 2009 Something between a 3-3.25/1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 6, 2009 (edited) I'm running a 3.15:1 in mine. 2,800rpm in 5th @ 100kph. Calculated top speed of 245kph in 5th. I'm more than happy with the ratio. With the bigger engine I could have gone to a 2.97:1 for slightly better economy.....depends what you want. What manual gearbox did you fit ?? Edited August 6, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
BMWTouring 20 Report post Posted August 8, 2009 I'm running a 3.15:1 in mine. 2,800rpm in 5th @ 100kph. Calculated top speed of 245kph in 5th. I'm more than happy with the ratio. With the bigger engine I could have gone to a 2.97:1 for slightly better economy.....depends what you want. What manual gearbox did you fit ?? I havent converted it just yet, just want to get all the bits together. Must check what diff ratio is in there at the moment as I'd rather do the job all at once and do it properly. Quote Share this post Link to post Share on other sites
