bmw325i 0 Report post Posted September 19, 2009 Just had an idea... Has anyone tried or know what the outcome would be of putting a m3 or mayb even a 330 airflow sensor in the 328? I know from old days in the silvias, if you put a rb20det airflow sensor in a sr20 you get a power and response increase through tricking the motor into sucking more air/more fuel etc, so thought id see if anyones done it to a bm. Let me know Jase Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 20, 2009 The sensor must match the DME to operate correctly. Getting a remap by Gavin will achieve more Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted September 20, 2009 I modded exhaust, fitted headers and had Gavin Re-mapp ECU. Huge differance in lower to mid range. Torque is up to 205flbs ATW [Auto]. Quote Share this post Link to post Share on other sites
Driftit 2248 Report post Posted September 21, 2009 Just had an idea... Has anyone tried or know what the outcome would be of putting a m3 or mayb even a 330 airflow sensor in the 328? I know from old days in the silvias, if you put a rb20det airflow sensor in a sr20 you get a power and response increase through tricking the motor into sucking more air/more fuel etc, so thought id see if anyones done it to a bm. Let me know Jase It is also the same with Silvias. You have to map the ecu or get an aftermarket one to run an R32 or Z32 AFM on a SR20. Quote Share this post Link to post Share on other sites
