mitchE30 0 Report post Posted October 4, 2009 hi just has cylinder crack of my 320i.and I have a 2.3 le tronic engine complete.can I use 323i head for my 320i? Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted October 4, 2009 Sure can. Align the timing marks before you drop it on. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted October 4, 2009 Why not throw the entire 2.3 in instead, if it's a complete motor? Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted October 4, 2009 Why not throw the entire 2.3 in instead, if it's a complete motor? Do this. Quote Share this post Link to post Share on other sites
mitchE30 0 Report post Posted October 5, 2009 Sure can. Align the timing marks before you drop it on.I found the 2.3ltr timming mark is different for the 2.0ltr.half teeth forward.do i need to change the cam gear for 2 ltrs? Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted October 5, 2009 even better put M20B25 in from a facelift e30 325i or early e34 525i Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted October 5, 2009 I found the 2.3ltr timming mark is different for the 2.0ltr.half teeth forward. do i need to change the cam gear for 2 ltrs? Wow you work fast.. it shouldn't be half a tooth off, all the heads are timed the same and the gears are the same. have you got a timing belt on there? Tried cranking it round a few times? Tensioned correctly? All be it you should be using a NEW timing belt btw, Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 5, 2009 Half a tooth on the crankshaft is one tooth on the camshaft...recheck your timing marks Quote Share this post Link to post Share on other sites
