mitchE30
E30 cylinder head replace
hi just has cylinder crack of my 320i.and I have a 2.3 le tronic engine complete.can I use 323i head for my 320i?
Sure can. Align the timing marks before you drop it on.
I found the 2.3ltr timming mark is different for the 2.0ltr.half teeth forward.
do i need to change the cam gear for 2 ltrs?
even better put M20B25 in from a facelift e30 325i or early e34 525i
Guest FrantiC
Wow you work fast..
it shouldn't be half a tooth off, all the heads are timed the same and the gears are the same.
have you got a timing belt on there? Tried cranking it round a few times? Tensioned correctly?
All be it you should be using a NEW timing belt btw,
Half a tooth on the crankshaft is one tooth on the camshaft...recheck your timing marks
