Munts316i
Punching Out Ski Hole
this is the culprit. if you have an angle grinder taking this out should be a matter of minutes, but if not get a powerdrill, a hammer and a file ready and you'll be done in under 10
Edited by Munts316i
Wow, mine took a few seconds - kick, wigigle, wiggle, pull, done! Then a file to tidy up.
Forget the angle grinder if you have a tricky one - get an oxy-acetalene baby, yeah!
A right o i might have to do it
Whats the cabel for??
Edited by cage
power for the amp.
you put that blue one to the head unit to when the car is on the amp is on and when the car is off the amp is off ;)
so you dont lose all your power to the amp when you want it off
Edited by CADMAX
so when you put a sub in, you can actually hear it.
not entirely true, but go for it, as long as you angle the sub to the rear
oh and FACELIFT only cars.
im not sure if i can attack mine if theres nothing to attack.
i might make my own ski hole.
Funny, mines pre F/L and i took mine out. Mine is late 87 so that might have something to do with it.
Guest Andrew
mines '84 and has nothing to punch out either.
