Braeden320 0 Report post Posted October 28, 2009 Im interested to hear how people run the ipods/mp3 players in there cars, Im sure theres plenty of you that do. I have the factory 6 CD Stacker with Steering Wheel controls in my ST220, It has a button on the Headunit that says CD/AUX. I quick search on the net says that the aux input for my car is in the glovebox, but I havn't checked that out as yet.I want to hook and MP3 player in the system somehow as it just makes sense. Have looked at FM Tuners that run of the cigy lighter but unsure about sound quality etc. Open to all ideas Cheers Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted October 28, 2009 Glovebox connection sounds like a great option if you can give it a try? Quality will be a million times better than an FM tuner mate Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted October 28, 2009 For your particular h/u. Go through Aux, look in your glove box and see what cables needed, most likely 2xRCA or 3.5mm jack - Easiest and best option for you. For mine, I have a direct iPod connection - Best possible quality For a mates, he runs an iTrip style device that transmits the MP3 player through a radio frequency - poorest quality. Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted October 28, 2009 FM tuners are crap, do everything you can to hook it up with AUX before you even consider one. In fact Id rather burn cd's all day than use one ! Are there any ST220 forums in the UK ? Id bet money someone has already done the hardwork for you and worked out how to do it if there is. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted October 28, 2009 The Renault has I-Pod cable and control, the Beemer has a direct input I-Pod cable and the I-Pod simply docks with it and is controlled from the head deck. You can get a I-Pod cable that can splice directly into your aerial input. Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted October 28, 2009 Looks to take a 3.5mm jack in the glovebox. So you would run a cable from there, to the ipod? Sorry im a n00b at car audio, Looking to buy a complete setup. Cables, Ipod etc Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted October 28, 2009 Yes sir. 3.5mm to 3.5mm. From the headphone jack on your ipod to the Aux in. Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted October 28, 2009 I'd say aux is the best. when using my ipod using the ipod controller on my headdeck i find it kidna slow to respond to and u need a decent head unit to even navigate through all ur playlist, folders etc. I like aux because u have the ability to just quickly using the ipod to pick songs faster (when u have pulled over of course:P). Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted October 29, 2009 X2. Aux is best, just buy a car charger. Quote Share this post Link to post Share on other sites
greenday-rulz21 4 Report post Posted October 29, 2009 If I had money to upgrade the headdeck etc. I would get one with an Aux input. It is the best way to put your iPod through your car stereo without spending a fortune on a head deck that is actually good at iPod control. I use an actual iTrip. Not a cheap/sh*t fake. Its not that great around town but is pretty bloody good for something that is wireless in the countryside, especially good on roadtrips. But I first heard one in Turangi which gave me a good impression of them. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted October 29, 2009 I use an itrip as my CD Player doesn't accept aux input (surprising considering it is hardly entry level!). itrip is flexible as I can take it from vehicle to vehicle, but quality is barely acceptable, esp in the BMW for some reason. It's OK, but as others have said aux is the way to go. Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted October 30, 2009 So i got the 3.5mm Plug, a Samsung MP3 player and loaded it with music but the headunit isn't picking up that anything is plugged into the AUX. Any ideas? Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted October 30, 2009 Shouldn't you just press whatever you press to switch from like, CD > Radio > AUX like most headunits? Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted October 31, 2009 Yep,not working. As the wires move when the glovebox opens i suspect that they are broken inside. Reading online it seems to be a fairly common problem. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted October 31, 2009 Ah, bummer. Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted November 1, 2009 UPDATE Got it working,Turns out that the AUX feature had never been turned on, Couple of menus in the headunit that I hadn't found before that needed the settings changing to get AUX to work. Penry you were right, A guy from STDrivers forum was able to help out. Quality is bloody good so stoaked with the end result. Cheers for all the help Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted November 1, 2009 Internet wins again Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted November 2, 2009 Different question, similar topic. Other than CD's where do you all buy your music from online? Not interested in File Sharing sites either.Want to do it the right way I don't have an Ipod, just an 8GB Samsung MP3 player if that makes a difference. Cheers.. Quote Share this post Link to post Share on other sites
